1999 Mustang Cobra
99' Cobra ABS issues
When I first bought the car about month ago I noticed that the abs light was on and did a "test" to see if it was working and indeed it wasn't. So I did research and found out it is often the speed sensors on each wheel, so yesterday I found the time to get under the car and clean and inspect the the pickups and rings. I pulled the negative cable for 10+ minutes then said a prayer and fired it up. Much to my disappointment even though the car had not moved the the ABS light came on immediately and has stayed on after about 30 minutes of test driving to see if it would un-f#*k it's self. Anyone else have this problem or no why it would come on instantly after resetting the computer and stay on?
Thanks for your help in advance.
MM CC Member #68 |
Moderator
you can test the sensors with a DMM (digital multi-meter). I would check the connections and make sure that they havent come loose or something. Other then that IIRC the ABS system works differently then the SES codes. ABS codes are stored until they are physically erased by and ABS reader or the problem fixed.
![]() ![]() BUILD 2 IN PROGRESS |
#3 | |
1999 Mustang Cobra
MM CC Member #68 |
Moderator
i can find out for you. you will also need to check the resistance between the pins on the harness to make sure that they are within range.
1999 Mustang Cobra
Thanks for the help.
MM CC Member #68 |
Moderator
no problem
Threads Similar to: 99' Cobra ABS issues
| ABS light and cobra swap question | bigred7999 | 99-04 | 4 | May 6th, 2009 10:30 PM |
| Abs vs non abs for rear end swap? | bansheex | 94-95 | 2 | March 17th, 2009 08:09 AM |
| ABS and NON-ABS Axles... HELPSSS | John's_stang | 99-04 | 6 | October 8th, 2008 12:43 AM |
| Kenne Bell on 99' Cobra | Lefty | General Tech | 3 | January 18th, 2008 12:33 AM |
| ABS fried on my Cobra | 97svtcobra | 96-98 | 4 | February 5th, 2007 09:49 PM |
