Need help with transmission fluid!
Old February 11th, 2010, 01:11 PM   #1
Teknicz's Avatar
99 mustang cobra
Teknicz is on a distinguished road
Need help with transmission fluid!& apparently this guy and his diff oil lol
Okay so where do i check the fluid level for the tranny i want to do a tune up. yea dont be harsh i only had this car for a month. Is it on the tranny itself?
NO CATS NO GLORY SLP LOUDMOUTH FTW
MM Cobra Club #57
Old February 11th, 2010, 01:28 PM   #2
bitemark46 has a spectacular aura aboutbitemark46 has a spectacular aura about
Yes. Crawl underneath on the pass side of thet tranny. There is a bung you have to remove. It says "fill" next to it. Once you take it out if fluid comes out its full. But depending on the miles I'd just drain it and refill it. The drain plug is on the same side too. I fill the tranny through the shifter hole. Less messy.
-Mark-
98' N/A Cobra (Stock longblock)
11.79 at 114.64 (1.62 60ft)
Old February 11th, 2010, 01:40 PM   #3
Teknicz's Avatar
99 mustang cobra
Thank you I appericate it
MM Cobra Club #57
Old February 11th, 2010, 01:48 PM   #4
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
dont meed to thread jack, but ima bout to change my diff. oil anything i should know before i do it, also gonna be chaning to a trick flow cover.
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old February 11th, 2010, 02:13 PM   #5
Teknicz's Avatar
99 mustang cobra
i think i made the title more reasonable lol
MM Cobra Club #57
Old February 11th, 2010, 02:16 PM   #6
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Old February 12th, 2010, 01:29 PM   #7
T.B.A
hahaha good looking out man lol
Beauty & The Beast
Old February 12th, 2010, 01:41 PM   #8
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
with the diff the less messy way is to loosen the top bolts a little bit then the other bolts most of the way without taking them out that way you can pry the cover just a little to let the fluid come out into a drip pan. If the TF has a fill bung then just put the cover on and fill through there.
BUILD 2 IN PROGRESS
Old February 12th, 2010, 03:52 PM   #9
T.B.A
cool thanx man, ima replace tha whole cover and the new tf has a fill hole so it will make it easier, im putting back some lucas oil back in along with a bg product
Beauty & The Beast
Threads Similar to: Need help with transmission fluid!
transmission fluid v8muscle 5.0 Mustangs 10 November 17th, 2009 07:00 PM
how much transmission fluid ? adrenaline=lifeline 99-04 20 March 26th, 2009 10:19 PM
T-5 transmission fluid fastford3388 5.0 Mustangs 20 May 31st, 2008 10:20 AM
What Transmission Fluid? Murderjetz General Tech 8 November 10th, 2007 11:39 PM
transmission fluid firefly1241 5.0 Mustangs 10 April 1st, 2007 04:33 PM
