Teksid or WAP block?
LinkBack (4) Thread Tools
Old February 16th, 2010, 11:32 PM   4 links from elsewhere to this Post. Click to view. #1
MiKeYbAnKs3435's Avatar
2001 SVT cobra
N/A
MiKeYbAnKs3435 is on a distinguished road
Send a message via AIM to MiKeYbAnKs3435
I know you can id which engine block you have by checking some of the patterns located on the block. Can you tell which block you have by looking at your SVT owners manual? In my owners manuel, it says "logitudinally mounted, 90-degree v8, cast aluminum cylinder block and cylinder heads". I was just wondering if I had a teksid because I believe the WAPS were made out of Iron and not aluminum. The guy I bought the car from also stated something about the block having 6 bolt mains. Can any of this info determine if I have a teksid? Thanks!
Imports are like tampons. Every pussy's got one.
Old February 17th, 2010, 12:29 AM   #2
99CobraAR's Avatar
1999 Mustang Cobra
99CobraAR is on a distinguished road
The owners manual doesn't say which block you will have but it will definitely be an all aluminum block and unless it is a very earlier 01 it will be WAPS. It's supposed to be a little bit weaker of a block. They didn't switch to cast iron until the 03-04 cobras.
MM CC Member #68
Old February 17th, 2010, 01:07 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
owners manual wont say. there are ways to find out if you look.
Old February 17th, 2010, 01:51 AM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
if you are facing your engine and you look to the left of your alternator and underneath the intake manifold, with a flashlight, you will see either a square pattern or a diamond pattern inside the intake valley. If they are square you have a teksid, if they are diamond then you have a WAP. Technically speaking both the teskid and WAP have only 4 bolt mains with a jack screw on each side starting from outside the block for a total of 6 bolts.
BUILD 2 IN PROGRESS
Old February 17th, 2010, 02:14 AM   #5
99CobraAR's Avatar
1999 Mustang Cobra
I just noticed you were in N.W. Arkansas, where about? What track do you go to? I'm in Arkadelphia and my closest track is Prescott but I'm not a big fan.
MM CC Member #68
Old February 17th, 2010, 03:08 AM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the teksids have jack screws and side bolts. the WAP's only have side bolts.
i am in bentonville.
Old February 17th, 2010, 03:15 AM   #7
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
damn, Sweet, nice catch. WAPs use a one time TTY side bolt where as the Teksids incorporate a side bolt to preload the side of the main cap then the jack screw goes through the side bolt to secure it. Better
BUILD 2 IN PROGRESS
Old February 17th, 2010, 03:19 AM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
there ya go, you made up for it
Old February 17th, 2010, 03:11 PM   #9
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
teskid>wap
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old February 17th, 2010, 03:12 PM   #10
T.B.A
*teksid
Beauty & The Beast
Old February 25th, 2010, 09:49 AM   #11
NomadGT's Avatar
NomadGT is on a distinguished road
This my Teksid Block
Old February 25th, 2010, 12:17 PM   #12
mpe331lx's Avatar
9.74@142
mpe331lx will become famous soon enough
Are you positive thats not a FWD Teksid form a Conti? I've never seen a Teksid with the smooth area in the middle and the oval looking boss with the squares in it. Did you pull it from a car, or purchase it as a block? You may want to run the casting numbers.
Old February 25th, 2010, 02:58 PM   #13
Reloaded's Avatar
2004 Mach 1
Reloaded is just really niceReloaded is just really niceReloaded is just really niceReloaded is just really niceReloaded is just really nice
Send a message via AIM to Reloaded
Hmmm... Interesting. This is a pic of my teksid block out of a '99 Cobra:
MM Cobra Club #42
417 HP & 413 TQ (Old #s)
422 HP & 453 TQ (New #s)
492 HP & 502 TQ (with Posi and 2lb lower)
Originally Posted by BuRnIn_YoUrS View Post
Dude...it takes alot to make me gag...
Old February 25th, 2010, 03:59 PM   #14
2001 SVT cobra
N/A
I tried looking under the intake manifold and still couldn't get a good enough look to tell
Old February 26th, 2010, 03:58 PM   #15
NomadGT's Avatar
Pulled it from the 93 Mark VIII myself
http://www.moddedmustangs.com/forums...-98-cobra.html
Not all Teksid Block are the same.
Old February 26th, 2010, 07:21 PM   #16
mpe331lx's Avatar
9.74@142
Cool deal. Its just an odd one then, lol. I had Teksid's from 93, 94 and 98 mark8's, 96, 98, and 99 Cobra's and none of them looked like that, lol. Must have been one of the first runs. My 93 was probably a later run which had the same valley as the others.
Old February 28th, 2010, 02:24 AM   #17
NomadGT's Avatar
Old March 8th, 2010, 01:05 AM   #18
2001 SVT cobra
N/A
I'm saying this hypothetically, but what if one decided to swap out his WAP block with a teksid? How much would one be and what would the overall swap be on a PITA scale?
Old March 8th, 2010, 07:18 AM   #19
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
just to swap blocks is not bad, longs you know what you are doing and have the little things you will need.
Old March 8th, 2010, 10:37 AM   #20
T.B.A
unless u wana make serious power just stick to tha wap.
Beauty & The Beast
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/153551-teksid-wap-block.html
Did all 99 Cobras come with a Teksid Block? - Yahoo! Answers This thread Refback June 5th, 2011 12:56 PM
Did all 99 Cobras come with a Teksid Block? - Yahoo! Answers This thread Refback November 20th, 2010 04:28 AM
Did all 99 Cobras come with a Teksid Block? - Yahoo!Xtra Answers This thread Refback November 20th, 2010 03:04 AM
Did all 99 Cobras come with a Teksid Block? - Yahoo! Answers This thread Refback November 20th, 2010 02:36 AM
Threads Similar to: Teksid or WAP block?
teksid block? Boostang 99-04 6 July 24th, 2009 12:58 PM
Teksid block ? PaintedBlack 99-04 6 May 28th, 2009 11:42 AM
Teksid block HMStang217 4V / SVT 12 January 19th, 2009 07:10 PM
Teksid block? RandoGT 4V / SVT 23 November 26th, 2008 03:33 PM
WAP Block mustangman36578 96-98 1 April 16th, 2007 11:04 PM
