Difference Between 8.5:1 CR and 10.1:1 CR
Just Curious as to what the New 5.0 w/ 8.5:1 CR will run like in Comparison to the Stock 4.6 w/ 10.1:1 CR. I'm mostly concerned with Gas Mileage and Driveablity. Noticeable Power Difference is something im expecting but how much? Just curious Since I've decided not to go with Boost, (Other Expenses), for a little while longer... Like 1-3 years longer.
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. |
MM's Orangest
2004 Mach 1 Mustang
I could be wrong but I thought the new 5.0 was closer to 11 CR.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
2003 SVT Cobra
I'm not sure what the new motors have, but 8.5:1 is LOW for a n/a motor. I think that's what the supercharged Cobras come with.
![]() 03 Cobra-Slow 02 SS, 00 Z/28-Gone Rest In Peace Travis Billings
KB'd GT
Low compression = bag mpg, and low power, but is good for high boost.
's
2000 gt
That low compression without a blower will be a dog. BetteR get some 4.30's.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
<Ed Macmahon voice> "Yes, you are correct sir" </>
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
2000 gt
I think he's talking about a 5.0 stroker for his car
Granny Shifter
Nothing is exact, but given the same motor, if the only thing changed is compression, a guideline is 4 percent power gain for every full point of compression added.
Sorry,it's a stroker Shortblock build. I went with Cast iron block , forged internals , but a boosted format. So CR is somewhere between 8.5:1 - 9.1:1.
Lol, I hear you there. I was considering 4.10's
I Poop Entirely Way Too Much
Blown 03 GT
With compression that low your gonna need a big PD blower
My original intent was to go with a decent size Procharger Kit.
As for functionality it won't do any harm to the motor itself will it?
Blown 03 GT
Too high of compression could be a problem. But a motor with 8.5:1 compression is goni to be a dog with out a BIG roots/screw type blower. Even with a procharger your not gonna make boost soon enough to offset the low compression. Usually u would run 9.0:1 compression with a roots/screw blower and around 9.5 with a centri.
I've used a couple different calculators but for some reason I'm getting the feeling there not very accurate.
as in Powerdyne?
those belt driven book case ends? Those are the worst thing to put on a car if you are serious about power. not worth the material they are cast out of
Blown 03 GT
PD or positive displacement blower refers to any manifold type blows, Whipple and Kenne Bell included.
Lost me there.
Threads Similar to: Difference Between 8.5:1 CR and 10.1:1 CR
| The Difference? | wannabeimportkiller | V6 Mustangs | 33 | May 4th, 2009 09:38 AM |
| difference? | Got Ford | 4V / SVT | 8 | September 6th, 2008 02:54 AM |
| any difference? | tsp_2177 | 2005 - 2010 | 18 | March 20th, 2008 01:51 PM |
| Difference? | shroom | 99-04 | 12 | February 4th, 2007 11:33 AM |
| What is the difference if any... | franchise | Modular Mustangs | 0 | December 14th, 2006 09:21 AM |
