RPM jumping with deforst on
Old February 21st, 2010, 03:53 PM   #1
1996 Mustang Cobra
96whitesvtcobra is on a distinguished road
Ok so I have had a probleam with my car idling up and down for the last few months. I have replace the IAC valve and done a complete tune up and it is still there. The idle jumps about 400 rpms up and down it seemed to only do this with the heater on. Will last night I noticed it only did it when you had it on deforst or mix not on vent or just floor. It even jumps when your not at idle at like going 20 miles an hour though tone you can fill the car idling up. I know the vents are controlled by vaccum and I know on my 96 jimmy the knob selector went bad and caused a vaccum leak. Could this be the same thing? If so what it the part called that controls the ac/heater vents?
Old February 21st, 2010, 03:55 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
When the A/C is kicked on, the idle is raised to compensate for the extra parasitic drag.
When the defroster is kicked on, it also kicks on the A/C, as air from the air conditioner is dried, and thus defrosts better.
In short, this is normal
O o
/¯/______________________
\_\
Old February 21st, 2010, 04:16 PM   #3
1996 Mustang Cobra
It is not the fact that the idle is rasied that is my concern it is that it jumps up and down. It is not stable with the deforst on.
Old February 22nd, 2010, 03:15 PM   #4
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
my idle goes pretty high as well when i turn on my defroster
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old February 22nd, 2010, 05:33 PM   #5
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
If it's jumpin up and down you either have low 134 or the low pressure switch is bad. You can jump it to tell. Turn on just the ac I bet it'll do the same thing. The clutch is kicking on and off, raising the rpms with it.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old February 22nd, 2010, 07:31 PM   #6
1996 Mustang Cobra
I just tested this and it does do it when the AC is on also. Just winter so I did not notice that. . I checked the ac and according to my gauage it is in a acceptable range. How can I test the low pressure switch?
Old February 22nd, 2010, 07:55 PM   #7
2000 gt
You can jump I somehow, can't remember exactly how. Search it should come up
HARDCORE CREW
Old February 23rd, 2010, 02:10 PM   #8
1996 Mustang Cobra
Just to get all the info in one place you jump it just by jumping from one wire to the other. There is only two wires on it. This was the issue with mine. Thank you very much. Rep points for you.
Old February 23rd, 2010, 08:03 PM   #9
2000 gt
if it's in acceptable range then hopefully that's your issue.
my car isn't in the acceptable range, it's gonna take some work. don't know where i got a leak from or how to find it. sucks.
HARDCORE CREW
Old February 24th, 2010, 01:09 AM   #10
1996 Mustang Cobra
I'm sure you already thought of this but I know here they sale r134a with a dye in it so you can find leaks just a idea. Had to use that on my pickup.
Old February 24th, 2010, 01:36 PM   #11
T.B.A
mine has a leak or something as well, it only works when it wants 2
Beauty & The Beast
Old February 24th, 2010, 02:08 PM   #12
Trick Tuners's Avatar
KB'd GT
Maybe its a vacuum leak? Does the rpm jump only when the compressor is cycling? Maybe the compressor is on its way out.
Old February 24th, 2010, 02:14 PM   #13
T.B.A
my rpms go up when compressor decides to work
Beauty & The Beast
Old February 24th, 2010, 02:15 PM   #14
KB'd GT
That sounds pretty normal to me, but 400 rpms is a little high. Are you tuned? If so, you could ask your tuner to lower it a bit.
Threads Similar to: RPM jumping with deforst on
Engine Jumping and RPM Bouncing. bloodusmc V6 Mustangs 39 June 6th, 2009 03:16 PM
Need help jumping time Yella01Stang 99-04 0 May 25th, 2008 02:56 PM
engine jumping around bad :[ emgjsdk1 99-04 3 February 16th, 2008 06:55 PM
car jumping a fence fogged306 The Clubhouse 11 July 15th, 2007 08:24 PM
rpms jumping jh3rlh 5.0 Mustangs 4 March 26th, 2007 02:08 PM
