conversion question!!!!! - Page 2
Old March 3rd, 2010, 02:59 PM   #21
2005 GT & 69 Mach1
rxnodoze02 is on a distinguished road
Maybe? That is just what I heard about the plates I heard they are very specific to the cobra bc of the electronics. Maybe I’ll just go with the heads from the navi. What do you think. If I do go with the navi heads which ones. There are a set for sale but off a 4.6. Now are those no good bc they came from a 4.6 block and they were made for a diff deck height as well right. If so what do you think I should look for? thanks
Old March 3rd, 2010, 03:16 PM   #22
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
koessl will become famous soon enoughkoessl will become famous soon enough
You can use the Cobra heads still. From what I know... all V8 Modular heads are interchangeable between blocks. But the ports are different between the models. Which is why you would need a different intake. I personally would use the Navigator 4V heads/same Navigator intake. But thats because I dont want to spend a million dollars on a custom intake manifold.
WAIT! you can use the cobra heads, and intake but you would need these...
Reichard Racing
$375 for the adapter plates. They compensate for the added deck height (space between the heads as well).
Military Crew
Completely stock... I promise.
Old March 3rd, 2010, 03:17 PM   #23
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
That lifts the intake up an inch and brings the mounting points for the intake in a little bit so it fits the new dimensions... so unless you have an aftermarket cowl hood.. or want to cut a nice hole in your stocker, that may not work.
You may have to do that anyways because of the added deck height.
Military Crew
Old March 3rd, 2010, 04:22 PM   #24
2005 GT & 69 Mach1
Ahh thats the ticket. Now I will just buy the 98 cobra heads and used those adapters so no big deal. The reason for this whole thing is my friend gave me a 5.4 engine and I want to do something with it but have been phased out of the modd motors. I have a 05 with a 4.6 and I have learned from building push rod motors unless you want to spend some coin making power. Go with a sc. To get the small blocks making 150rwhp extra you spend thousands anyway. For four big ones slap on the sc and call it a day atleast thats my take. Well to make a long story short now I never got into the internals of the modd motors. Thanks for all the help tho. By the way those plates are big bucks . Now I have to get a car to put it in. What about the whole engine managment. Can I just drop this engine in a 96 gt and then have it dynoed?
Old March 3rd, 2010, 04:40 PM   #25
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
You can delete the plates.
You can also give me the motor... ill manage it, then you dont have to worry about it!
Military Crew
Old March 3rd, 2010, 04:51 PM   #26
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
hah ^ nice. it depends on which route your going...if you go from 2v to 4v im not sure it will run properly if at all. if its 2v to 2v or 4v to 4v then it will run rough but you could limp it to a dyno or something.
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old March 3rd, 2010, 05:05 PM   #27
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
I figured it was worth a try ya know?
Military Crew
Old March 3rd, 2010, 05:17 PM   #28
2003 Mustang Cobra
10.88@131 shakedown pass
4sdvenom is on a distinguished road
You can't use those plates for the 96-98 heads. They don't make them for B-heads. Those plates are to adapt a 99+ (C-head) intake to a 5.4 Navigator headed 5.4 motor. The Navigator heads have larger ports than any 4.6 4 valve head, so you have a few choices unless you want to degrade performance by mismatched ports or spend lots of money on custom stuff!
1) Use the Navigtor heads and use a Navigator intake (straight bolt-on).
2) Use the Navigator heads and use a 5.4 Sullivan intake (straight bolt-on).
3) Use the 99+ 4-valve C-heads and use a widened 99+ 4-valve C-head intake (straight bolt-on once intake is widened)
4) Use the 99+ 4-valve C-heads with an Aussie Boss 290 intake (Australian intake designed for c-heads on a 5.4, not impossible to get but pricey)
5) Use whatever heads you want and spend 3-5K having a custom intake made from scratch for it!
6) Save your money and buy a Shelby GT-500 crate motor with the blower all as one unit and benefit from the Ford GT heads it has.
7) Use Navigator heads and the linked adapter plates to run a 99+ 4.6 Cobra intake (unwidened).
Good luck, but it sounds like you have a bit more reserch to do before you buy. I don't mean that in a bad way, but even though some things are interchangeable doesn't mean there is the supporting componants available to make it work. i.e. yes 96-98 B-heads will bolt to a 5.4 block, but no there is no intake available or adapter plates available to make a 4.6 intake work with them!
Ken
2003 Black Cobra coupe - DOA - Currently holding down my jackstands.......again
Old March 3rd, 2010, 05:27 PM   #29
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
ahhhh... glad someone else chimed in then!
Military Crew
Old March 3rd, 2010, 05:31 PM   #30
2002 mustang gt
upstang can only hope to improve
WAIT your saying i can put four valve heads from a cobra onto my 2002 5.4 2 valve truck motor?
Old March 3rd, 2010, 06:07 PM   #31
2003 Mustang Cobra
Yup, but you will have to change the timing cover, and locate the front accessories to the proper location for the year 5.4 4 valve timing cover you use. Then you will have to pick the intake choice thats appropriate for the heads you use from the options I listed a few posts above. You will have to verify that you can use your harness, but will most likely have to switch to a 5.4 four valve engine harness. (A cobra harness will work with modifications). You will definetly need a tune. Then there are all the little parts like fuel rails, fuel injectors, COPs, Primary timing chains, secondary timing chains, tensioner arms, tensioners, crank sprocket for timing chains, valve covers, COP covers, new coolant hoses, new thermostat parts (new location), etc. that you will need to source from a 4-v 5.4. I'll tell you from experience. I was doing this swap in my Cobra and it was much easier to start with a 4v 5.4 Navigator motor that I purchased from a salvage yard in running condition for $1400 than to think about piecing all the stuff together to get it right.
Ken
Old March 3rd, 2010, 08:34 PM   #32
2005 GT & 69 Mach1
haha. Your prob right I should give it to you so you could burn a hole in your pocket instead. Because im sure you know thats whats gonna happen Thanks for all the help I def have a much better understanding of how to go about this. They do make adapter plates so the 4.6 can work on the 5.4 the link is up top. Reichard racing check it out
Old March 3rd, 2010, 09:33 PM   #33
2003 Mustang Cobra
I know exactly what it takes to do this swap, and I definetly won't be burning a hole in my pocket to do it. Thats why I scrapped it and decided to do a 5.3 build with the Boss 5.0 block and a stroker kit. I know about those plates, but they only work for a 99+ intake on a Navigator headed 5.4 as I posted above!
Good luck with the build!
Ken
Old March 4th, 2010, 01:12 PM   #34
2002 mustang gt
how much more horsepower can the 4v 5.4 make over the 2v 5.4
Threads Similar to: conversion question!!!!!
Another conversion question???????????? TimboStang Drag 3 April 22nd, 2009 03:04 PM
Another 5 Lug Conversion Question ttopoutlaw 5.0 Mustangs 13 November 22nd, 2007 10:25 AM
5 lug conversion question TtopFoxRod50 5.0 Mustangs 1 November 23rd, 2006 07:07 PM
I Have A Question (Convertible Conversion) GTsetGO Classic Mustangs 3 October 24th, 2006 04:51 PM
Maf conversion question? 88Horseman 5.0 Mustangs 7 October 22nd, 2006 07:21 PM
