zippeewannabee
4v with T45?
well i plan to do a termie swap here in the next few months, but i have figured that the motor without trans is much cheaper (usually). I eventually plan on swaping the trans out with a stalled C4, but in the time being will the 45 be ok?
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
9.74@142
It should be fine. The gears in the t45 are pretty strong. It is the shift mechanisims that are somewhat failure prone. If it has held up so far, you will probably be allright with it behind the Cobra motor.
zippeewannabee
ok, thanks for the input. any idea what all i would need for the swap?
97 Cobra
It's iffy at that power level without a rebuilt T-45. You might go 2 years or 2 months. Way too many variables.
My advice.... Dont overclutch the car. Run a softer sidewall tire to absorb more shock. Get a well balanced driveshaft with the proper pinion angle. Dont drop the clutch at 6K especially if you have good traction, and let the rpm drop a hair between your 1st to 2nd shift. Not saying to granny it but dont go all pro slamming into 2nd 50-100 rpm from redline. I'm not saying you need to do any of this for it not to break, but if you're worried and a tranny failure would really rock your world financially possibly leaving you without a car...... I'd follow that advice. Have fun and keep us updated on your swap
Converted to the Dark Side. 06 Apex Silver Evolution IX GSR - Turboback Exhaust, Tune - Wideband O2, Trustz backlight gauges, Apexi turbo timer - Stock wing, but soon to be wingless. - Guessing 280-310 at the wheels. 02 Red Escape V6 4x4 |
#5 | |
Moderator
![]() ![]() BUILD 2 IN PROGRESS |
zippeewannabee
thanks for the info guys
1998 mustang cobra
how much did the promotion rebuild cost you? was it rebuilt to stock specs or upgraded for a higher HP application?
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
Threads Similar to: 4v with T45?
| T45 v. T5 | riddlee josh | V6 Mustangs | 3 | November 3rd, 2009 08:36 AM |
| t5 < - > t45 | phoenix99 | 96-98 | 19 | March 20th, 2009 06:19 PM |
| t45 | jkovacs60 | 99-04 | 1 | February 21st, 2008 07:23 PM |
| t45 | RC02GT | 96-98 | 13 | February 20th, 2008 07:28 AM |
| T45 | mantis99 | V6 Mustangs | 4 | November 2nd, 2006 03:31 PM |
