1999 SVT Cobra
RPM's Don't Drop Back Down After Rebuild??
Alrite guys help me out, i just rebuilt my 99' cobra engine with a new forged rotating assembly, L/T's, and a new clutch, i honed out the cylinders and made sure i had a good cross-hatch, and the crank turned almost by hand, it was a thing of beauty
so i started it and ive put about 300 miles on it, its smoothing out alot, but when i shift, or bring the rpms up, they dont drop immediately when i let off the throttle like normal, or even close to normal, makes for an annoying shift. i compression tested each cylinder, everything was good around 200 psi, and i did a leak down test, checked for vacuum leaks. all sensors are working properly and no check engine light or anything is on any ideas guys? ![]() the heads are also the only thing i didnt touch, just took them off, then oiled them up and put them back on once the new rotating assembly was in
1999 Cobra w/ saleen Extreme body kit -18" Saleen 5-spoke rims w/ Nitto NT-05's -JLT cai, Momo competition wheel ![]() -H-beam Rods, 10.5:1 flat-top pistons -L/T ARH headers w/ high-flow 3" X-pipe, magnaflow custom mufflers, Spec Stage 3 Clutch |
Safud: MM's Resident Hadji
Mine does that every once in a while also
1999 SVT Cobra
haha isn't it wonderful
it wasnt doing it too bad before the rebuild, im not sure. i flashed the computer and it got a little better, but i can definately tell its still doing it
97 GT and 03 Cobra
12.75@105
can you take a video of it? are the rpms staying up when you let off or are they just dropping slower than usual?
![]() 2003 COBRA FOR SALE PM FOR DETAILS |
1999 SVT Cobra
they hesitate for a second when i let off the throttle and then really slowly come back down.
i don't even have a video camera haha x)
1998 Mustang Base Model
i would check the iac, they go bad often and when they do they stick. It wont always set a code either if its just starting. Take off the iac and check for carbon build up. Also, if the batt was dissconnected for an extended amount of time it may have reset the computer. I have seen it several times where after just the time it take to chance a battery it will reset and cause this type of issue. However, i wouldnt suspect that since you have driven it over300 miles already...that should have been enough time for it to relearn, usually it only take a few miles, 10 or 20 tops. If you dont have any vac leaks i would most likely suspect the iac.
97 GT and 03 Cobra
12.75@105
did you put an aluminum flywheel on it?
1999 SVT Cobra
nah no flywheel, just a resurface.
im pretty sure its my MAF sensor, i checked the codes and it says that Bank 1 is running too rich, and a few people have told me that people often oil up their air filter and it destroys the MAF sensor :/
97 GT and 03 Cobra
12.75@105
yea if you over oil your filter it gets on the wire and ruins it, you can try to spray it off with brake cleaner to clean it. also im not sure if mustangs do this or not but some cars run a cleaning cycle with the key on engine off, it super heats the maf to burn anything that may be on the signal wire.
1999 SVT Cobra
hmm interesting. im gonna try a few things. i have a JLT CAI, if i end up having to replace the MAF should i go with a 90 mm? there isnt a specific one for my intake and the filter i have doesnt look like it will fit any of the aftermarket sensors
KB'd GT
1999 SVT Cobra
thats a good forum
i tried everything there and it helped alittle, but its still noticabally hanging and coming down slow, i keep hearing its the MAF
Moderator
+1, tried these and it corrected it but every sooo often it still did it. Joe (Tricktuners) tuned it to damn near almost gone but it would creep back once and awhile, used to be 10x worse before the tune. Ive read from different forums that it was attributed to either the maf, the intake, or the screen from the original intake.
The theory is that with certain CAI when you are coming to a stop being that the MAF is down there so low that it still senses air coming in thus increasing the idle. Some have also thought that the screen not being there was the culprit. I tested it out and my problem was attributed to the CAI and the maf being soooo low. I put my stocker on for about a month and no issues what so ever and this was after checking my TPS reading, MAF, IAC, vacuum leaks, etc.Not saying that it is your problem but hope it helps.
![]() ![]() BUILD 2 IN PROGRESS |
1999 SVT Cobra
thanks wraither thats exactly what im thinking is the issue, on account of the massiveness of the JLT intake haha. im gonna try the stocker and see what happens
Moderator
no problem brotha
1999 SVT Cobra
well got a new MAF on the way, hopefully that does the trick
Threads Similar to: RPM's Don't Drop Back Down After Rebuild??
| RPM's just won't come down | frodo2975 | V6 Mustangs | 18 | June 20th, 2010 12:17 PM |
| high rpm's | Bush18 | 99-04 | 10 | October 11th, 2009 02:11 PM |
| Average RPM's? | Tigerwhite1 | V6 Mustangs | 7 | September 25th, 2008 09:31 AM |
| Idle Rpm's | 96GtGoodz | 96-98 | 19 | December 5th, 2007 12:15 AM |
| Drop the Front More Than the Back? | GTSilver | 99-04 | 16 | November 21st, 2006 02:01 PM |
