help with clutch
Old March 6th, 2010, 12:09 AM   #1
blown96stang's Avatar
2001 Mustang Cobra
blown96stang is on a distinguished road
Send a message via AIM to blown96stang
help with clutch
my cobra has 70,000 miles on it and i put in a spec 2+ clutch, FRPP pilot and t/o bearing, and resurfaced my flywheel.
i have been drivin on my new set up for 2 days remebering the 500 mile break in period so no WOT and only 2.5k shifts
My problem is everything sounds good and correct EXCEPT i hear a metal on metal type of sound and im 90% sure its my new t/o bearing ridiing along the input shaft and causing this noise
i think old t/o bearing scuffed my input shaft or sumthing iono and now the new one has no lubrication
i bnought some bearing grease to see if i could lubricate the input shaft but i wanted to ask u guys if u have any suggestions?
or am i totally wrong and u guys think its something else?
please help like my new setup but i want it to be 100%.
MM Cobra Club #35
Old March 6th, 2010, 04:08 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
only way to find out, is to pull it back out.
Old March 6th, 2010, 10:58 AM   #3
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
is it constant? Does it only happen in a certain gear? At a certain rpm? I get a noise with my 2+ only when I'm letting the clutch out in first and im not in a certain little window for my rpm's but it's more of a squeek kind of noise,
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old March 6th, 2010, 11:54 AM   #4
2001 Mustang Cobra
in lower rpm range and only when i acclerate. any gear
MM Cobra Club #35
Old March 8th, 2010, 10:50 AM   #5
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
im hearing a scratching noise once in a while taking off on first gear slowly
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Threads Similar to: help with clutch
Clutch noise? New clutch install mtbr101 99-04 0 December 8th, 2009 10:08 PM
Clutch Or Clutch Cable OR Shifter??? 96GtGoodz 96-98 21 July 27th, 2009 02:59 AM
clutch replacement- replace whole clutch assembly or just clutch disc? WilltheThrill 4V / SVT 12 December 13th, 2008 12:18 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
