check engine light came on....
Old March 8th, 2010, 06:53 PM   #1
tomasmk2003's Avatar
2003 Mustang Cobra Convt
tomasmk2003 is on a distinguished road
Send a message via AIM to tomasmk2003 Send a message via Yahoo to tomasmk2003
Hey guys I was doing a little driving around today. Will admit was running my car a little harder than usually. But still prob was only running around 4-5k rpm's. Never went past 80 mph. At once point I was accelerating my car just sorta quit on me. If I had to describe it felt like when you hit the rev limit the engine turns off. Felt just like that. I look down at my dash and see the service engine light come on and flash for about a minute before turning it's self off. Car seemed fine but... What would cause that to happen and anything wrong that I should have it look into more from a mechanic?
Old March 8th, 2010, 08:05 PM   #2
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
I would have that code read, its still in memory. A handheld tuner is the best thing you can have ex: SCT, superchips etc.
Build #1249
MM New Edge Crew Member# 6
Old March 8th, 2010, 08:07 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
flashing SES means multiple misfires detected
BUILD 2 IN PROGRESS
Old March 8th, 2010, 09:18 PM   #4
I do have a sct tuner. So plug it in and it should give me a code? Far as misfires detected that referring to spark plugs or...? Sorry I'm not the best with car mechanics.
Old March 8th, 2010, 09:20 PM   #5
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
it honestly can be a number of things from fuel, plugs, COP's... etc... best thing to do is to start with the small stuff and go from there. Pull the codes, if there is any, and let us know what youve got.
BUILD 2 IN PROGRESS
Old March 8th, 2010, 09:26 PM   #6
Alright I'll do it tomorrow after work.It's my secondary car not my daily driver so wont' be driving it for a few days anyways. Thanks for the help so far. I'll be sure to see if it gives me a code.
Old March 8th, 2010, 09:28 PM   #7
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
no problem at all. defintely dont drive her until you figure out why that happened.
BUILD 2 IN PROGRESS
Old March 8th, 2010, 09:35 PM   #8
Well after it happen I still had to driver her 25miles or so. Seemed alright but something seemed different. Not quite as loud anymore. Have borla stingers. But I could be be hearing things
Old March 8th, 2010, 09:41 PM   #9
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
I think she's alright, you would definetly feel a huge difference if something bad happened.
BUILD 2 IN PROGRESS
Old March 9th, 2010, 02:11 PM   #10
Okay i have two codes....
P0234
Description: Turbo/supercharger tc/sc over boost condition
P0306
Description: Cylinder #6 misfire detected.
What should I do and how bad are these two. Thinking misfire on the cylinder is prob the worst of the two.
Old March 9th, 2010, 03:19 PM   #11
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Pull the plug on cyl 6 and see how shitty it is lol. If not I'd check the coilpack. Start there for the misfire. Cheapest first
As for the P0234 let me look into it.
Old March 9th, 2010, 03:23 PM   #12
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
+1, whens the last time you changed your plugs? pull them, change them if need be and then take coil 6 and swap it with another to see if the code follows the coil. If it does then you know what it is. Cricket had the same problem with his car and, IIRC, it was attributed to bad plugs.
BUILD 2 IN PROGRESS
Old March 9th, 2010, 03:30 PM   #13
Hmm, honestly little more mechanical then I think i can handle. Lefty maybe your available sometime in the near future. Was 45minutes apart? I'd pay ya what you think is fair.
Old March 9th, 2010, 03:31 PM   #14
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
it honestly not hard at all. But i totally understand if your not comfortable with it. Lefty may be able to give you a hand.
BUILD 2 IN PROGRESS
Old March 9th, 2010, 03:35 PM   #15
I wish i knew more about cars and had hands on experience but I have zero exp.
Old March 9th, 2010, 04:01 PM   #16
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
I'll have to get back to ya man. I'm swamped with school and work; I barely have enough time to fix my car sometimes
Lol, but we'll figure something out. Worst comes to worst Primo and I will walk you through checking the plugs out
Old March 9th, 2010, 04:02 PM   #17
Lol good luck with the walk thru I dont' even know how to change my own oil sad to say. Guessing I shouldn't go driving her around until its the problems are resolved?
Old March 9th, 2010, 04:32 PM   #18
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
i wouldnt just to be on the safe side. Whenever my car threw a code I never drove her until I got the code corrected.
BUILD 2 IN PROGRESS
Old March 9th, 2010, 07:30 PM   #19
Well one of my neighbor's who does some mechanical work look at the car. He mentioned I'd have to do quite a bit of unbolting just to get to the plugs. He also mention the throttle cable was loose. I noticed it before but just how loose or tight should that be? I had 2 mechanics look over the car before buying it in December. Probably haven't even put 500miles on it sense owning her.
Old March 9th, 2010, 08:17 PM   #20
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
They are a little loose on our cars. Nothing to be worried about at all. There is actually a $3 mod that you can do with hardware store parts to make it tighter. Now as far as the plugs go there really isnt alot to it. Make sure that the engine is cold before you pull them though.
On top of each valve cover there are 2 cover plates that hide the COP's and plugs. The D/S one has 32 valve on it while the P/S one is just plain. there are 2 10mm bolts holding each one on. Remove them and place them aside. With the P/S you may have to disconnect the intake tube assembly in order to get access to it. Not hard at all. Now when you get the covers off pull off the COP's and arrange them somewhere so that you know where they went this way you can tell if that #6 coil is bad later on. When you get these off move the harness aside. Now take you a ratchet with and extension and a 5/8" spark plug socket and take the plugs out. If they are hard just turn it a little at a time to break them loose. Once you get them out check to see their condition or post pics up here. Now get new plugs and put a little anti-sieze on them.
Now to put everything back together is just the opposite but this time take the #6 coil and swap it out with another one so that you can see if the code comes back and if and when it does if it followed the COP that you swapped out. EX... if you swap out the #6 coil with the #7 and you get a code for a misfire on #7 cylinder then you know you have a bad coil.
BUILD 2 IN PROGRESS
Threads Similar to: check engine light came on....
check engine light 01COBRA 4V / SVT 0 November 7th, 2009 09:55 PM
check engine light MisterFast3 V6 Mustangs 5 August 12th, 2008 12:52 AM
Check Engine Light? 03_StangGuy 99-04 5 July 15th, 2008 01:04 AM
Check Engine Light 02MiNeRaLgRaYGT 99-04 3 November 21st, 2007 02:00 PM
Check Engine Light? GreenFaleen V6 Mustangs 13 November 20th, 2006 03:26 AM
