Lifters
I have a few questions about lifters for a 99' Cobra.First,where would I buy them??Second,Are they hard to Install??Should I get used ones or aftermarket performance ones??
Co-Owner Hooker Trade industryFX4 CREW Crew Member #4 Say Bye to McMustang5.0 http://www.moddedmustangs.com/forums...mcmustang.html |
Moderator
why are you looking into lifters? is there a reason why you are looking into replacing them?
Lifters can be purchased from your ford dealership they are about 200+ per set. I dont know if anyone makes aftermarket ones but the stock ones are adequate. In order to replace them you will have to remove the roller rockers which takes a special tool to compress the valve spring and make it easier to remove the rocker. then you can remove the lifters, and just so you know they are hydraulic and not solid.
![]() ![]() BUILD 2 IN PROGRESS |
Okay well you know that 99 I was looking at??Well my bother in law bought it off from under me and that could be one of the reasons why the oil pressure is dropping right?
Moderator
it could be anything from a small thing to a large problem. did he not get it checked out before he purchased it and what makes him think that the lifters are to blame. is there any sounds or anything?
IDK I was on my way to buy it when the guy called me and told me he sold it and yes he had his buddy come and his buddy has built a few termis and other ponys and he said that it could be the lifter
Moderator
damn, so the car was checked out by his buddy. Not trying to be a dick but the seller could have got his buddy to say anything and you guys dont personally know him so how would you know that he knows what he is talking about. Your brother in law should have taken the car to a mechanic and got a full check done. Before you guys start assuming that this one thing is wrong take it to a qualified mechanic and have them do a check to see what they think it could be
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
if there is oil pressure problems, not likely to be a lifter.
No you misunderstood my brother in laws friend went with well my brother in law who like I said has built up about 15 ponies.
Moderator
I was getting there just seeing why he was thinking there was lifter problems, way to sink my boat there Mike
![]() OP if you need lifters talk to this man ^ as he might be able to do something for you.
mm's nitrous mod
2000 mustang gt
Moderator
![]() Ive got an excel sheet of things I need from you once I get it finalized
Okay but what do you think it is??Do either of you think it is the sensor??
Moderator
as ive said in your previous thread, it could possibly be the sensor. Ive had mine drop from the halfway mark to low pressure. At first I though it was the sensor but it turned out to be the wiring for the harness was grounding out to something and was throwing off the signal. Only way to check is to get under there and replace the sensor (they are cheap) and check the wires.
Okay I will tell him.
Co-Owner Hooker Trade industryFX4 CREW Crew Member #4 Say Bye to McMustang5.0 http://www.moddedmustangs.com/forums...mcmustang.html Last edited by HRV6STANG; March 29th, 2010 at 11:58 PM. Reason: Forgot the period. |
Threads Similar to: Lifters
| The lifters? | Johnathon | V6 Mustangs | 19 | December 11th, 2011 02:29 PM |
| what lifters? | McMustang5.0 | 5.0 Mustangs | 0 | November 6th, 2009 10:42 PM |
| lifters | 2000GTCONVERT | 99-04 | 6 | September 4th, 2009 11:42 AM |
| Which lifters ??? | 86_Notch | 5.0 Mustangs | 4 | March 23rd, 2008 11:56 AM |
| lifters | terribleonexx88 | 5.0 Mustangs | 9 | March 11th, 2008 07:37 PM |
