Mach 1 vibrations?
Old April 3rd, 2010, 08:08 AM   #1
04MachOne's Avatar
2004 Mach 1
04MachOne is on a distinguished road
Mach 1 vibrations?
I got my 04 mach 1 this week and noticed that when it hits around 22-2300 rpms, it'll make some like scratching noise. Sounds like it's coming from the rear passenger side of the car. Anyone have any idea what this is or if it's a big deal? Thanks.
Old April 3rd, 2010, 09:22 AM   #2
The_Frid is on a distinguished road
can you be more specific? what kind of scratching? metal on metal scratching ?
01 Cobra - 373s, K&N CA Intake, Bassani O/R X and catback
Old April 3rd, 2010, 04:07 PM   #3
04MachOne's Avatar
2004 Mach 1
Not really sure sounds like a high pitched vibration almost. Or like ripping tape off of something. haha It seems to be around 2500 rpms but only when I'm gassing, when I slowly pass 24-2500 it doesn't do it.
Old April 4th, 2010, 12:06 PM   #4
13.2
Mustang02gt is on a distinguished road
maybe change your rear diff fluid and check for metal shavings. least that point you could some what narrow it down after that.
Old April 4th, 2010, 12:34 PM   #5
bluestang41505's Avatar
2003 Mustang GT
bluestang41505 is on a distinguished road
Check your exhaust and make sure its all tight and the hangers too. Those rpm's is around the "drone" part witch would vibrate the exhaust alot. at least i think so
03 True Blue Mustang GT, 180 degree thermostat, UPR Offroad X, Flowmaster 40's, Steeda Tri-Ax, Fuzion 245/45R17 ZRi. 2 ten in' JL Audio W2V2, JL class D amp, Alpine head unit, Alpine speakers and amp, custom ported sub enclosure.
Old April 4th, 2010, 03:27 PM   #6
04MachOne's Avatar
2004 Mach 1
I'll be sure to check those thanks guys. I did notice the right exhaust pipe hangs a little lower than the left so that might be it.
Old April 5th, 2010, 12:36 PM   #7
Crisco is on a distinguished road
Could it possibly be the driveshaft?
Old April 5th, 2010, 12:53 PM   #8
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
Drive shaft will cause vibrations at certain RPMS if it is out of balance.
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old April 5th, 2010, 01:00 PM   #9
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
how would you ballance out a driveshaft i have this problem?
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old April 5th, 2010, 01:05 PM   #10
01 Cobra Vert
Nov 09/10 ROTM!
Remove the driveshaft and take it to a driveshaft shop.
Military Crew E5
Old April 5th, 2010, 01:15 PM   #11
T.B.A
serious?...because i remember i did my clutch job and when i put back tha drive shaft at 2600rpms it vibrates till i go 2 higher into tha rpms...how much do they charge and wat do they do to them?
Beauty & The Beast
Old April 5th, 2010, 01:17 PM   #12
01 Cobra Vert
Nov 09/10 ROTM!
All of them charge different prices. It is pretty much like balancing a tire. lol
As for your situation, I have seen cases that you can actually remove the driveshaft, rotate it and the reinstall it to get it to balance back out if it was balanced before you removed it the first time.
Military Crew E5
Old April 5th, 2010, 01:26 PM   #13
T.B.A
yea cuz i did remove it an turned it but im guessing i need to turn it again...i dont even know if theres a drive shaft shop around here
Beauty & The Beast
Old April 5th, 2010, 09:38 PM   #14
04MachOne's Avatar
2004 Mach 1
Yours is sounding like this at a specific rpms as well when you're gassing it? If I very slowly accelerate pass the rpms it does this at it won't do it, but when I'm say accelerating normal it will. It won't do it while sitting still revving it up past the certain rpms.
Old April 6th, 2010, 10:54 AM   #15
T.B.A
ill be driving normaly and when i get to like 2600 theres a vibration then goes away if i got past 2600rpms
Beauty & The Beast
Old April 6th, 2010, 02:26 PM   #16
04MachOne's Avatar
2004 Mach 1
Well yesterday I had to put my seats down in the back to put something in and when I drove it with the back seats down I noticed that it was coming from somewhere in the trunk. It must just be something loose or something of that sort back there.
Old April 7th, 2010, 03:23 PM   #17
2003 Mach1
13.615
281 4v FTW is on a distinguished road
I actually have the same problem at around 2000 rpm. sounds like something vibrating.
Old April 7th, 2010, 04:47 PM   #18
04MachOne's Avatar
2004 Mach 1
I'm pretty sure mines coming from the trunk, put your seats down and see if ya'lls is coming from the same place as well.
Threads Similar to: Mach 1 vibrations?
Vibrations at 75+ 90Stang 2005 - 2010 24 November 19th, 2009 01:38 AM
vibrations ia07gt 2005 - 2010 13 August 21st, 2009 12:02 AM
vibrations zinc02GT The Clubhouse 9 July 8th, 2008 06:28 PM
vibrations MikeD05GT 96-98 5 May 1st, 2008 11:09 AM
Vibrations! sneezingfox 5.0 Mustangs 35 April 7th, 2008 10:04 PM
