1999 SVT Cobra
my rear suspension is HORRIBLE..
i just did a big rebuild on my 99 cobra, and everytime i take the car past probally 75 mph the entire rear end moves up and down side to side all over the place :/ i bought two new tokico shocks but havnt installed them yet, should those solve the problem? or will i need springs too
also theres some drivetrain lash when i get on it then let of the gas, it "bucks" a little bit :/ any ideas? any feedback would be greatly appreciated
1999 Cobra w/ saleen Extreme body kit -18" Saleen 5-spoke rims w/ Nitto NT-05's -JLT cai, Momo competition wheel ![]() -H-beam Rods, 10.5:1 flat-top pistons -L/T ARH headers w/ high-flow 3" X-pipe, magnaflow custom mufflers, Spec Stage 3 Clutch |
Looking at the moment
shocks will not help with your rear end jumping (side to side) around like that. I'm not up to date on a 99 svt's rearr end but if its a solid rear axel and you havent done anything to it, then it could be simple things like bushings and alignment if your putting more power through the drive train then the weakest link will show itself and you will basicly work backward till your problem is solved. I would take it to a shop and have them double check the alignment first and go from there but with the rear jumping all around sounds like something bigger. But start easy before you throw money at the problem you have to realize that the urethane bushings (knowing ford they are probably just rubber) will wear out over time and rot.
----------------------- My Current play thing 2004 Alabaster White Crossfire LTD. ![]() My Next mistress will be ALL FORD.
2001 Mustang Cobra
I have a 2001 cobra and it was hoping up and down. Took it down to the local shop and they said it needed new bushings, since then it runs great.
The 99/01 Cobras have IRS |
1999 SVT Cobra
lol yeah i should swap, yeah im thinkin bushing and a full alignment will be my best bet
hey Fitz how much did they run you with labor?
I have been reading up on this, it is more common than you think with 99 cobras. I guess it is primarily the subframe bushings on the IRS that are crap. YOu can almost even hear like a clunk when you let off or get on it. The best rear end bushing kit for the money that I have found is a company called (full tilt boogie) they use a solid Delrin bushings instead of urethane, so no squeak either. Supposed to be a pain in the ass to replace everything in the rear, about 16 hours work, and that is for someone that does it every day.
I did just replace all the shocks in mine and I will note that the ride is way better and feels more solid, not soooo much rear end compression and wheel hop. |
Thread
Here is a thread that I had read and it most acurately describes what my issue is. Not sure if it would be related to the problem you are having.
2001 svt cobra
no way (IRS)
Build #1249 MM New Edge Crew Member# 6 |
Full Tilt Boogie Racing Homepage
Go here its the rubber vs. poly I would do this and a rear rebuild at the same time so you only have to go in onces and knock it all out! ![]() but its going to be a pita just so you know. lol
That is what i heard about that kit. it is a PITA but worth doing the whole thing at once.
2003 SVT Cobra
bruce's kit isnt that bad. Just make sure you rent his install/removal tools. If you have a hydraulic press handy it will make things much easier but it can also be done with a large d clamp, some boards and 1/4 steel plate..............Also if you have a drill press handy.......go ahead and spring for the grease fitting kit.
My buddy and I did Bruce's full kit in one day.......from dropping the irs, swapping the bushings, and throwing it all back into the car...........You'll be amazed at how much better the irs will feel..........Oh and also make sure to upgrade the front subframe bolts, it will help get rid of that "clunk"
I buy car mods for the stickers, and I have ALOT of stickers! Travis Billings May 6, 1982 - July 5, 2011 Rest In Peace brother, you will be missed. |
1999 SVT Cobra
alrite sounds like a plan, i have bushings on order along with bolts, should be havin alot of fun next weekend
it wasnt as bad until i pulled the engine, did a rebuild(added 80 ponies), and put a stage 2 SPEC on, now the rear end is just horrible
Threads Similar to: my rear suspension is HORRIBLE..
| rear suspension | 98Cobra_sleeper | 4V / SVT | 14 | October 14th, 2009 09:51 PM |
| rear suspension | bigtom | 4V / SVT | 16 | September 3rd, 2009 06:48 PM |
| rear suspension | White Thunder | 5.0 Mustangs | 8 | December 7th, 2008 12:38 PM |
| rear suspension | angermgt | 5.0 Mustangs | 1 | July 30th, 2007 12:05 AM |
| Rear Suspension Help | sn-95aac | 5.0 Mustangs | 3 | October 7th, 2006 06:30 PM |
