How Variations in Pistion Size Change Affect Performance?
Just curious because I ran across someone who has 9cc pistons which seemed to me rather on the small side. So how would the difference in sizes change performance, particularly when dealing with boost? If my question seems to be a little to vague, ask I'll try my best to clarify.
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. |
2003 gt
5.4 32v on the way
Different sizes are for different compression. You should try to get as much compression as you can pull off safely for whatever you are trying to do with your car.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
So , my guess, the bigger the piston the lower the CR? He was running the 9cc Piston, Twin turbos on a New Edge Mach 1. Made a little over 500 rwhp @ 10 #'s but when he tried to up the boost he ran into a few problems, mainly on the upper end.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
-xxcc is a dished piston, if no - then you are looking at a domed piston. more dish=lower compression. i bet he has -9cc dished piston, especially on boost.
oh.... im still a bit lost. I'm just curious because I myself am running 21.1cc Dished Pistions. But what I'm getting from you the figure is more like -21.1cc?
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. Last edited by Techniq; April 14th, 2010 at 11:35 PM. |
mm's nitrous mod
2000 mustang gt
correct. a +xxcc piston is domed and raises compression.
Thanks for clarifying. Feels good to learn something new.
Looking at the moment
----------------------- My Current play thing 2004 Alabaster White Crossfire LTD. ![]() My Next mistress will be ALL FORD.
Threads Similar to: How Variations in Pistion Size Change Affect Performance?
| i dunno if it would affect anyone here | 707Stang | The Clubhouse | 3 | November 6th, 2008 07:38 PM |
| How to change tire size on tuner | Black Sunshine 07 | 2005 - 2010 | 1 | June 12th, 2008 10:38 PM |
| Exhaust pipe size performance | squiggly | General Tech | 2 | April 25th, 2008 01:27 PM |
| Intakes variations | yellowstang6r | V6 Mustangs | 18 | March 26th, 2008 11:06 AM |
| Does Heating Affect Hp like AC does? | mustangmanic | 99-04 | 2 | November 9th, 2007 05:26 PM |
