1998 Mustang Cobra
How Hard Is Doing Cams?
Just wondering how hard it is to do a set of cams in my 98 cobra? I know Ill need springs and retainers and all that stuff but how hard is actually doing it? Odds are itll be in my garage with no specialty tools available and being very green to actually tearing into this engine. A guide or some know how would be really appreciated.
![]() " When in doubt, go flat out"- Colin McRae MM Cobra Club #76 MM Cleavage Club #14 285 CREW #8 |
MM's Orangest
2004 Mach 1 Mustang
Just going off of what others have told me, a DOHC motor probably isn't the best choice to pop your cherry on.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
1998 Mustang Cobra
yeah thats probably very true. i helped my buddy put a .500 mutha thumpr in his 350 but that was a whole different ball game. I will be going through engines next winter in school so maybe then would be a good time? i still would like to know what all it entails though.
2003 SVT Cobra
take the cam swap on the 350 and amplify that by 4...........take setting the degree on the 350 cam swap and amplify that by 100.
I buy car mods for the stickers, and I have ALOT of stickers! Travis Billings May 6, 1982 - July 5, 2011 Rest In Peace brother, you will be missed. |
1997 Mustang Cobra
8.65@84mph
i would give it to a shop unless you have someone there with you that knows their way around. Just my .02
N/A 4v Guru
2003 Mach 1
Most definatly not a shadetree mechanic job, you need some special tools and you really need to pull the heads or the motor there is no room in there
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
1998 Mustang Cobra
yeah i know that now. i loooked on alldata at work a few days ago and just the list of specialty tools is a half page long.
2003 Cobra
Im a tech at a ford delaership, I dont mind working on these motors.. but dont look foward to it.. haha.. but like everyone said.. 4Vs are not for the timid.. ensuring proper cam timing is a must.. if not, you just turned that 4V into a big ol paper weight..
MM Cobra Club #48 Mineral Gray Club Member #12 Im what you would call a "bad influence". |
1998 Mustang Cobra
Im a bit sceptacle to take my car to any ford dealer in North dakota because i honestly dont feel that any of them have any knowledge of nor have they worked on a 4v cobra. There arent many of these cars up here and the people that have them dont mod them. So im in a bit of a pickle here.
#10 | |
1989 Black LX---Turbo
As for the DOHC motor itself, I wouldn't advise a Novice to jump into one. I rebuilt the complete engine on my son's 97 Cobra and it was a learning experiance(and I'm an ASE Master Tech!) I'll have to say getting the cams lined up was the hardest part!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
It took me a week to do mine and I have done numerous 2v and 3v cam swaps. there is no easy way to do it, you need to set aside a weekend just to degree them.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
its not that bad. only takes a few hours.
+1 and a couple more if your learning, don't rush. You can always rent specialty tools from an auto part store.
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
Threads Similar to: How Hard Is Doing Cams?
| NSR Comp cams or hot rod cams | fallingaway2 | 2005 - 2010 | 6 | November 12th, 2009 07:14 PM |
| changing mach1 intake cams with 96-01 cobra cams?? | blue03mach1 | 4V / SVT | 19 | November 11th, 2009 02:11 PM |
| lunati cams vs. houston perf. vs. comp cams | mylilboostedpony | 99-04 | 0 | September 12th, 2009 06:05 PM |
