Cobra build
Old April 18th, 2010, 11:40 PM   #1
mustangmanv6@yahoo.com is on a distinguished road
Cobra build
My father and i have have been toying with doing a performance mustang cobra build for a while and now i'm getting serious. Would you give me your recomendations? This is what i have so far.
Base: 03-04 shell with wiring and computres
Engine Monitoring: HKS
Motor: 4.6 Teksid
FI- Twin turbo Garrett t3-60 with turbine of A/R: 1.06 (also could you explain what the A/R mean)
Transmission: TKO-600
Heads: 03-04 Cobra heads (port and polished)
Intake: Sullivan Intake Manifold
Cams: Yet to be determined (probably from Comp Cams)
Rear end: 200 series
Suspension: IRS
RPM Limit Goal:7,000 rpm
I would also like to run this on a low octane fuel...so if less boost is necessary then so be it
What i really want from this build is to have a very very very reliable 4.6 that could get as high as 30 mpg when not into the boost costing on the highway. I am looking at topping out of the boost at around 16 psi. I would like almost no boost from idle to 2500rpm (fuel mileage) (i know it sounds stupid but it WILL be driven). Also i would like to a very tall rear end. (again for fuel mileage). I would like to make around 500 hp and i would like for it to be extremely streetable as well. Please i am open to options and for any input as long as its not extremely negative.
Also should i wait and get a Coyote 5.0?
Thank you!
Old April 19th, 2010, 03:20 PM   #2
bump
Old April 19th, 2010, 04:26 PM   #3
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
You can meet your goals easy with the exception of the mileage. Get a set of custom grind cams to maximize the potential out of your car.
The new 5.0 is almost at 30mpg and the GT3 5.3L is making 560HP N/A (but that's a race car).
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old April 19th, 2010, 04:58 PM   #4
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Go with a SRA. Why keep IRS..if will hold you back. IMHO.
The block and PP heads is a nice combo if you. The stock cobra IRON block will take more power tho. But the Teskid does a good job too. I think around 800hp. Like Mach Boy said...costom cams will do you well too. But a good set of turbo cams will compliment it nice as well from a decent cams company.
You will still want to run a 3:27 to 3:55 gear ratio with a turbo setup(more load on the motor for a better spool on the turbos) so with a 6 speed your gas milage should be to bad.
Redline wise...that depends on where you make power and such. You can spin 7k but you may be past your rpm range of power.
Threads Similar to: Cobra build
98 Cobra Vert, I Have Your Build Certificate COBRA_ESQ 96-98 9 February 18th, 2011 10:05 PM
engine...cobra or build? energiesource 99-04 57 July 15th, 2009 12:32 AM
TT Cobra Build Comp JonnyB Videos 4 May 1st, 2009 04:03 PM
Cobra engine swap/build Reloaded 4V / SVT 18 April 27th, 2009 08:20 AM
Cobra build # 01silversnake 99-04 16 October 5th, 2007 08:38 PM
