#21 | |
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 Sold not lost and will never be forgotten. Last edited by CammedMysticCobra; May 2nd, 2010 at 04:51 AM. |
#22 | |||
The following are not my words. "Cited below" this argument has been recorded a thousand times. Volume is the same for every single turbo at the same psi and the same RPM. Smaller turbos simply cannot flow enough at higher RPMS to match bigger ones. Bigger turbos are nice, espcially with high rpm's becuase they can still produce 20+ psi of boost where the 16G would fall on its face and produce less boost and almost become a flow restriction. Also, bigger turbos are more efficient so they heat up the air less at any given rpm, thus 20psi from a 16g and 20psi from a larger turbo at a certain rpm has differences in temperature which leads to density differences. same psi on larger turbo makes more power than smaller turbo - evolutionm.net ---------------------------------------------------------------------------------- A larger turbo is able to move more air at a same rpm making it more efficient. A smaller turbo needs to rotate at a much higher rpm to produce the same amount of air flow. It heats up therefore creating hotter less reliable air.
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. |
#23 | ||
HP TT 57mm Kit on '04 Mach1 @ 10 psi made 516 Rwhp/ 517 Rwtq <- Not sure how good that is. I guess when he tried upping the boost he ran into some problems with the kit. Long story short..... He now has an F1a Procharger on it.
#24 | |
And you still havent answered weather you have an automatic or manual?
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 Sold not lost and will never be forgotten. Last edited by CammedMysticCobra; May 2nd, 2010 at 07:05 PM. |
#25 |
The point is, smaller turbos spool up faster then a LARGER turbo. so you make the potential hp faster and don't have max boost for only the high end of your RPM range.
the point of the videos was to show that a large turbo was gonna spool a whole lot slower then a smaller one. From what i hear... problems with running a big and small, is the tuning. but only from what i hear. You could always be a big money baller and go compound induction... but thats BIG money |
#26 | |
You were correct in your assumption..... Standard.
#27 | |
#28 |
As for as what set up/size turbo(s) that would most appropriately fit what I'm looking for, what should I look for when deciding?
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. Last edited by Techniq; May 3rd, 2010 at 06:02 PM. |
#29 |
I.D.G.A.F.
I believe Swervo is going to sell his kit, so you can probably buy that pretty reasonable...
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
#30 | |
So after reading everything I posted do you understand now or you still have the same opinions you tried correcting me with. Becuase your now asking what turbo to go with when all the info on what would be the best turbo is in my last post lol.
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 Sold not lost and will never be forgotten. Last edited by CammedMysticCobra; May 3rd, 2010 at 07:18 PM. |
#32 |
My goals for the car... im wanting something thats streetable for daily driving. As for power 450- 500 rwhp would work just fine for now. Ill later want to increase the power as I gain experiance with the car.
#33 |
i have 2 buddys that went from a whipple to turbos. they both have 03 cobras one with a t76 and the other with twin 61s. and they will both tell you that yes the turbos make more power but on the streets the t/s were a hell of alot more fun. and with turbos your always retune the car is that becomes a pain in the ass
#34 |
Yes this explains my point exaclty.
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 Sold not lost and will never be forgotten. |
#36 | |
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon. Last edited by Techniq; May 18th, 2010 at 05:49 PM. |
#37 |
No dude they dont and already told you the type of forced induction you go with has nothing to do with your gas mileage. What does effect that is your tune.
#38 | |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
If you're worried about the Procharger not having enough power off the line, spray a 50 shot. Nothing wrong with running nitrous off the line. How often are you at lower RPMs when you're drag racing anyway?
Do the Right Thing, Cook. ~Zip. |
#39 | |
2003 Mustang Mach 1
#40 |
Good Luck!
Threads Similar to: Looks like I'm going with a Large Twin Screw.
| Twin Screw v. Centrifugal | GTSilver | 99-04 | 14 | November 22nd, 2010 01:14 PM |
| Vortech TWIN SCREW??????? what what what??? | navyman8903 | 2005 - 2010 | 16 | March 16th, 2009 08:58 PM |
| Does anyone have a twin screw? | ChristOne | V6 Mustangs | 31 | March 16th, 2008 11:53 PM |
| KB Twin Screw | Dawgfude03GT | 99-04 | 23 | September 22nd, 2007 09:11 PM |
| twin screw? | GTSilver | 99-04 | 3 | August 30th, 2006 07:02 PM |
