Diff cover issues
Old April 27th, 2010, 09:19 AM   #1
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Diff cover issues
Having some problems removing the old one. Some very stubborn bolts. The two that larger ones that go on the end of the diff cover and connect it to the IRS. I'm trying to loosen those up, but since thats the part that tore the mount on the IRS just moves with it. Any tips on getting those off? Also it says to torque the bolts down to 80 ft lbs for the main caps, but the bolts on the diff cover itself are pretty easy to remove and the directions also say toque down to 10 ft/lbs. Little confused onto which bolts I torque down to 10 ft/lbs and which ones I torque down to 80 ft/lbs.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old April 27th, 2010, 11:58 AM   #2
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
This is going to sound real "hillbilly" but I just got mine nice and snug. Don't want to overtighten them. Zero problems.
Don't know what to tell you on the two bolts. It's been awhile since I removed mine.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old April 27th, 2010, 09:53 PM   #3
2001 Cobra
n/a
OldSVTGuy is on a distinguished road
Those two longer bolts that go through to the rear differential bushing are a PAIN. Ford uses a thread locker and I had to use a breaker bar the entire way on those. When you do get them out, use a drill with a wire brush attachment to get it all off; use blue thread lock when putting them back in. 80 lbs., as I recall, are on those two bolts. The differential cover bolts are like 10 pounds or so. I did this job last summer. The rubber bushings are really soft and it's no wonder the differential moves around so much. I replaced with poly and did a Billet Flow IRS brace, too. Hope you get those babies out.
Good luck..........
Old April 27th, 2010, 10:43 PM   #4
Eclipse27 is on a distinguished road
exactly what rk said
04 mach 1....
Threads Similar to: Diff cover issues
Diff cover JerseyTrueBlue 99-04 1 January 16th, 2010 12:02 PM
Ford Racing Diff Cover 06GTMustang89 2005 - 2010 46 May 15th, 2009 11:27 PM
Rear Diff Cover Muscletang 96-98 13 December 15th, 2008 10:47 PM
LPW diff cover plug size? BudgetPlan1 2005 - 2010 0 August 14th, 2008 10:21 AM
Roush Diff Cover Girdle Issue gsjohnson 99-04 14 November 9th, 2007 09:54 PM
