Steeda TriAx "Chink" Sound
Old March 12th, 2007, 02:32 PM   #1
Forbiden is on a distinguished road
Probably a stupid question but I'll ask anyways. Is there something added to the triax so that it chinks when changing gears, or is it standard?
My father had a Steeda Triax in his Bullitt and again in his Mach 1 and they both made this metal-to-metal sound when he shifted gears.
I'm just curious what causes this. Thanks.
Old March 12th, 2007, 05:19 PM   #2
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
i'm guessing the spring?
Old March 13th, 2007, 07:36 AM   #3
FaStStAnG5-0's Avatar
FaStStAnG5-0 is on a distinguished road
Send a message via AIM to FaStStAnG5-0
do they have adjustable stops that the handle could be hitting??
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
Old March 13th, 2007, 10:35 AM   #4
Possibly. It didn't seem to affect performance (of the shifter) so I can't really say. I just know it sounded pretty sweet.
Old March 13th, 2007, 12:08 PM   #5
i have a hurst shifter with the adjustable stops & when i shift hard the shifter will hit the stop & make a little sound but it isn't loud
Old March 15th, 2007, 08:27 PM   #6
True2theHorse is on a distinguished road
I have a Triax and yes there are adjustable stops, but the other thing is when you install the Triax (not sure about the hurst), you remove the factory noise dampening material etc... in the process so it is inherently louder. If you put the car in neutral you can hear the tranny gears turning too.
Old March 19th, 2007, 11:32 PM   #7
Racinjason81 is on a distinguished road
feed it an egg roll
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old March 20th, 2007, 07:01 PM   #8
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
I bought my mustang from an old lady who had no idea... maybe a previous owner changed the shifter, or maybe its stock with a different knob. It has a Steeda shift knob, but it makes the "chink" sound when I shift it. Not sure if someone just changed the knob or if they did the whole thing... How can you tell?
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Old March 21st, 2007, 10:26 AM   #9
FIVE-0's Avatar
FIVE-0 is on a distinguished road
Send a message via AIM to FIVE-0
take off the shifter bezel and look inside, most aftermarket shifters have there company name stamped on the shifter somewhere
Old March 21st, 2007, 02:33 PM   #10
+1 you'll be able to tell what it is when you look at where it attaches to the trans..
Old March 21st, 2007, 04:26 PM   #11
meh
Notcho's Avatar
Thanks, Ill check it out
Old March 21st, 2007, 07:08 PM   #12
meh
Notcho's Avatar
This is the shifter. The rubber boot was already torn back when I took it apart.. looks like someone was there before.
The handle looks like cast iron and old, so I would guess that its stock?
Old March 21st, 2007, 11:21 PM   #13
FIVE-0's Avatar
well it looks stock, but it looks aftermarket by the same rate, cause whoever installed it butched the crap out of your lower shifter boot, and did u see any where on there a shifter manufactureres name on it?
Old March 21st, 2007, 11:36 PM   #14
meh
Notcho's Avatar
Nope, I didnt see a name on it anywhere.
Its hard to tell with the boot on it, but I didnt want to destroy the only good one there. I did see that it has the studs that come out of the sides of the shifter, but idk the stock ones may have these too.
I was browsing through latemodel restoration site, looking for something with the similar rectangle shaped cast iron shift lever. The only similar looking one I could find was this MAC shifter:
Old March 22nd, 2007, 03:02 PM   #15
pull the lower boot off and post picture.the stock shifter on a mustang is a piece of stamped steel if its not its and its a thick piece of aluminum its aftermarket.check with a magnet.
Old March 22nd, 2007, 04:38 PM   #16
meh
Notcho's Avatar
Ok I'll do that today. I need to adjust the adjustable stops anyways. The shifter rattles in 2nd gear unless I hold the handle.
Old March 22nd, 2007, 07:08 PM   #17
meh
Notcho's Avatar
I couldnt take the boot off because it had a ring clip around it. To get to that I would have to take the console out so I could take off the plate that the upper (cut to hell) boot is attached to. The lower boot had a small crack in it so I could test it with a magnet. The lower plate that bolts to the tranny is aluminum, (the magnet would not stick) and as you can see in the pic, the black looking base where the adjusting stop screws are looks like the one at latemodel website. Also I dont believe the stock ones had stop screws. (the handle hitting the stop screws make the CHINK sound)
Old March 22nd, 2007, 08:59 PM   #18
FIVE-0's Avatar
it seems like its aftermarket, dno what brand, but if there are stops and the lower mount is aluminum, i doubt its stock
Threads Similar to: Steeda TriAx "Chink" Sound
Steeda Triax shifter mdvaldosta Parts 25 February 2nd, 2010 08:34 PM
"Clack Clack" sound :( FireHawk V6 Mustangs 8 November 7th, 2007 06:50 AM
Steeda TriAx and UDP's installed!! RStrick0352 2005 - 2010 4 May 23rd, 2007 11:22 AM
