96-98 Cobra OEM Cam Spec Info
LinkBack (3) Thread Tools
Old June 14th, 2010, 07:36 AM   3 links from elsewhere to this Post. Click to view. #1
97_4V_Sleepa's Avatar
97 GT w/4v Conversion
9.98@127.29
97_4V_Sleepa is on a distinguished road
Send a message via Yahoo to 97_4V_Sleepa Send a message via Skype™ to 97_4V_Sleepa
I was looking around on google and figured I would share this with you guys. these are the specs taken off of a set of brand new set of OEM 96-98 Cobra Cams for all of you guys sporting the "B" Heads.
CAMSHAFT Lobe Lift · Intake (Primary)
5.57472 mm (0.21839 in) · Intake (Secondary)
5.55672 mm (0.21877 in) · Exhaust (Both Lobes)
5.55152 mm (0.21856 in) · Allowable Lobe Lift Loss
Theoretical Valve Lift @ Zero Lash · Intake (Primary)
10.0 mm (0.3937 in) · Intake (Secondary)
10.0 mm (0.3937 in) · Exhaust (Both Lobes)
Just in case anybody was wondering. JB
Originally Posted by ChrisJ View Post
Look at the runners...This is
not a "stock" naturally aspirated intake...
Its for a big breathing engine...
Old June 18th, 2010, 07:51 PM   #2
V6 Pony Car is on a distinguished road
Are they the same across 96-98? I thought the 98s were a little "hotter"
Old June 18th, 2010, 09:17 PM   #3
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
they should be all the same, cobras are supposed to have slightly better cams than the other b head cars.
Old June 20th, 2010, 09:11 PM   #4
9.98@127.29
the cam specs are the same for 96-98 Cobra's. the 98's had a different theory on the ECU. This is why the cams seem hotter.
Old June 20th, 2010, 09:20 PM   #5
mpe331lx's Avatar
9.74@142
mpe331lx will become famous soon enough
Not just B head guys! The 96-98 intake cams are the best preforming out of all the stock 4.6 4v cams.
The 99/01 Cams coming in second place, and the 03-04 Cams the lowest (essentially the same as mark8 cams)
Some mach1 owners have reported a 15-20rwhp gain by swapping to a set of 96-98 intake cams (advanced 4 degrees). All stock 4.6 4v exhaust cams have almost identical specs.
Old June 20th, 2010, 09:41 PM   #6
2003 gt
5.4 32v on the way
anyone know the specs on the markviii cams?
Old July 23rd, 2010, 06:53 PM   #7
brharris777's Avatar
1998 Mustang Cobra
brharris777 will become famous soon enoughbrharris777 will become famous soon enough
so once i get my c heads i should swap my cobra cams back onto them?
" When in doubt, go flat out"- Colin McRae
MM Cobra Club #76
MM Cleavage Club #14
285 CREW #8
Old July 23rd, 2010, 09:02 PM   #8
2003 gt
5.4 32v on the way
Yeah, if you have them why not.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/170082-96-98-cobra-oem-cam-spec-info.html
Cobra 4v vs Mark8 4v - http://www.allfordmustangs.com/forums/4-6l-tech/148957-lincoln-mark-viii-swap.html been researching this due to the fact im told my car has a mark8 motor in it... mark8 and cobra motors are to different worlds apart... mark8 ma This thread Refback May 9th, 2012 07:30 PM
Cobra 4v vs Mark8 4v - Your talking about a different heads. 96-98 uses This thread Refback February 9th, 2011 06:17 PM
98 Cobra Specs - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback July 4th, 2010 10:41 PM
Threads Similar to: 96-98 Cobra OEM Cam Spec Info
Info on Spec stage 1/Ram HDX Clutches adam0421 2005 - 2010 2 August 10th, 2009 04:46 PM
Spec Stage2 Testing Waters,Need Info 330CubeGt 96-98 4 February 20th, 2009 03:16 AM
cam info spike spiegel 99-04 8 September 21st, 2008 07:09 PM
*Cam Info* Gotdatstang V6 Mustangs 8 December 11th, 2007 05:14 PM
