catback
Old June 15th, 2010, 05:55 PM   #1
04MachOne's Avatar
2004 Mach 1
04MachOne is on a distinguished road
catback
I'm having a shop put in my Magnapacks because I just don't feel like doing it without a lift and it'll only be about 60 dollars but my step dad is saying I should have it welded together and not bolted on since I'm having someone else do it anyways. Should I ask them to weld it together or will it be fine if they just bolt it up like normal?
Old June 15th, 2010, 09:18 PM   #2
Mustang03's Avatar
2003 Mustang Gt
N/A
Mustang03 is on a distinguished road
i think if you clamp it right you should have no exhaust leaks plus you can change out mufflers if you get bored with the mags
Old June 16th, 2010, 12:50 AM   #3
MikeJones's Avatar
13.7@103
MikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really nice
tell them to weld your tip hangers so they don't slide away.
Mod6
Bigbore
Kooks
(parting out 2v motor)
Old June 16th, 2010, 10:31 AM   #4
vita's Avatar
1999 Mustang Cobra
vita has a spectacular aura aboutvita has a spectacular aura aboutvita has a spectacular aura about
Send a message via AIM to vita Send a message via Skype™ to vita
clamping will work, theres no need to weld it all. As pointed out, weld the tips though!
Originally Posted by mrsinister2424 View Post
... I roll up with my retarded exhaust setting off car alarms and wetting panties for miles.
MM Cobra Club Member #51
Old June 16th, 2010, 02:17 PM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
if its the catback it should have the ball and socket connections to bolt right to the midpipe. There should be no welding involved in replacing mustang exhaust components, i.e. headers, midpipe, catback. It's all designed as a bolt in and unbolt system.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Threads Similar to: catback
catback red96stang 96-98 9 March 15th, 2009 12:34 AM
2.5 catback momogt 99-04 38 February 14th, 2009 09:44 AM
Which Catback.!! SilverGT04 99-04 83 September 13th, 2007 07:08 PM
