Cams???
Old June 16th, 2010, 12:19 PM   #1
chrisquirk187's Avatar
2003 Mustang GT
12.129
chrisquirk187 is on a distinguished road
Cams???
Hey guys, I really wanna throw a set of cams in. (stock internals)
My questions are:
Will stage 3 fit in my motor?
Will aluminum retainers be good for maybe 100 miles a week
other than a tune, retainers, springs what other supporting mods are needed or recommended (i.e. adjustable cam gears, bigger fuel pumps or 60lb inj, crank pulley, etc..)?
Finally how much of a power/torque gain am I looking at with the stage 3?
current mods are a 2.8 pulley, RAI, accufab 1700 cfm tb/plenum, KB BAP, and coolant tanks. with 3.23s I made 490rwhp after the 4:10 install I made 452rwhp
500+lbs of torque.
thx for all your help.
2003 Ford Mustang GT/Cobra
-04 Cobra motor swap (Dyno 490RWHP – 520FTLB as of 7-6-2009)
-T-56 tranny swap
-upper/lower control arms
-aluminum drive shaft
-Suede interior
-Candy paint exterior
MAD Crew #15
Old June 16th, 2010, 06:03 PM   #2
2003 Mustang GT
12.129
bump, some one has to know something about internals here.
-T-56 tranny swap
-Suede interior
MAD Crew #15
Old June 16th, 2010, 07:28 PM   #3
MikeJones's Avatar
13.7@103
MikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really nice
wait until tonight hits. Thats when most of us have nothing better to do.
I beleive with stage 3's you will need to notch your piston.
Mod6
Bigbore
Kooks
(parting out 2v motor)
Old June 16th, 2010, 07:38 PM   #4
2003 Mustang GT
12.129
thx, I sure hope not but we will see tonight.
-T-56 tranny swap
-Suede interior
MAD Crew #15
Old June 17th, 2010, 12:24 AM   #5
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
depends on cam manufacture. most will but some wont. as for the retainers, they will be fine, but titanium ones are highly recommended.
Old June 17th, 2010, 11:18 PM   #6
1999 Mustang Cobra
Not Yet
99cobra! is on a distinguished road
Send a message via AIM to 99cobra!
I didn't have to notch the pistons on mine. I got the XE278AH cams from Comp installed. I used steel retainers. How did you lose that much hp going from 3:23s to 4:10s.
<font face=Comic Sans MS><font size=5><i>The One and Only</i></font></font>
MM COBRA CLUB #19
"Real cars aren't powered by their front wheels, they lift them"
Old June 18th, 2010, 09:28 PM   #7
2003 Mustang GT
12.129
thx, The only prob with the titanium retainers are that the websites are saying its for limited street use and Im not sure why. I drive the car all weekend long and park it during the week under a cover so is that limited?
I just verified today that the power loss with higher gears is very true cause I did not believe the tuner at first. Gears give you a bunch more torque and torque is the first thing you see on a dyno. Once torque runs out hp takes over. When doing bigger gears you wanna ensure that your rpm doesnt hit your redline before the end of the quarter mile which mine is a couple hundred away and thats a "great thing" according to him. I just like seeing big numbers . Not totally sure what all that exactly means but it came from a 9 sec drag radial champ so I believe him.
thx again for yours guys help, Im starting to think that the amount of money for cams and a tune for 30-50rwhp just isnt worth the money. I can spend 2k and port the blower, 60lb injectors, 90mm MAF, 4lb crank pulley and get nearly 100.
-T-56 tranny swap
-Suede interior
MAD Crew #15
Old June 18th, 2010, 11:16 PM   #8
CammedMysticCobra's Avatar
Mustang MystiqueCobra2004
CammedMysticCobra can only hope to improve
Send a message via AIM to CammedMysticCobra
Well First off I have the biggest custom Comps you can fit a 03 04 Cobra 4.6 heads with serious bolt ons including Hooker long tubes, Steigy Stage 5, 2.8 upper, 2lb lower, and the custom comps and made 520hp 520lbs of torque with a rich tune, bad plugs, and the most important missing JLT CAI, Acufab TB, and Acufab Plenum.
If I would have had the JLT, Acufab Tb and Plenum with good tune and new plugs I should have made at least 570hp so I was basically making almost 50hp from my cams and thats because of their size.
You wont be able to make 100hp even with a stage 5 steigy and 4lb lower you dont even have long tubes and thats on top of the fact that if you run 4lb lower with 2.8 upper you will be over spinning the rotors on the charger like crazy you will burn them and your charger wont be making or holding boost properly and you will need to get a new set.
Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne
http://www.youtube.com/user/MysticCobra04
Sold not lost and will never be forgotten.
Old June 19th, 2010, 07:22 PM   #9
2003 Mustang GT
12.129
Congrats on your great power achievement.
Now, I do have Lont tube headers with an o/r h-pipe and magnapack catback. With the 4:10s I am showing 452rwhp (491 wih 3.23s). I figured that the steggy SNAKE BITE which is there latest/biggest port plus a crank pulley, 90mm MAF and 60lb injectors would put me at about 552 but I dont know everything. I appreciate the schooling on the 4lb lower, would you recommend a 2lb? Or none at all. I really wanna be part of the 500rwhp club with my 4:10s so any help is greatly appreciated.
My performance mods.
Engine:
-2.81 aluminum upper pulley
-Custom aluminum Idler and bracket
-Diablosport Predator
-NGK plugs
-Kenne Bell Boost-a-pump
-Twin Cobra fuel pumps
-Custom dyno tune from Justins Performance (Glen Burnie MD)
-T-56 6 Speed Transmission
-Aluminum Driveshaft
-Steeda cold air intake
-BBK O/R H-Pipe
-BBK long tube headers
-Flowmaster cat-back 40 series exhaust
-Steeda adjustable clutch cable kit
-PRO 5.0 Short throw shifter
-Hurst shift handle
-Centerforce DFX clutch
-RAM 11" Aluminum flywheel
-Weld in frame ties
-Accufab Polished 1700cfm Throttle body
-Accufab Polished 1700cfm Plenum
-Polished radiator cover
-Fluidyne Triple Layer Intercooler
-Canton S Aluminum Supercharger coolant Exp Tank
-Canton S Aluminum Supercharger Coolant Tank
-Aluminum Power Steering Tank
-Ice® synthetic coolant
-Max EZ power steering fluid
-T-56 tranny swap
-Suede interior
MAD Crew #15
Old June 23rd, 2010, 03:14 PM   #10
97_4V_Sleepa's Avatar
97 GT w/4v Conversion
9.98@127.29
97_4V_Sleepa is on a distinguished road
Send a message via Yahoo to 97_4V_Sleepa Send a message via Skype™ to 97_4V_Sleepa
how much HP did that polished radiator cover get ya'?....lol. Nice car man.
Originally Posted by ChrisJ View Post
Look at the runners...This is
not a "stock" naturally aspirated intake...
Its for a big breathing engine...
Old June 29th, 2010, 09:52 PM   #11
Engine:
-NGK plugs
-BBK O/R H-Pipe
-Hurst shift handle
-Weld in frame ties
Trust me you need the 2lb lower and no more than that if you want to get over the 500hp mark and if you get Snake bite port which Iam sure is the same as steigy stage 5 with a new name you should be good to go. And the snake bite seem a waste of money since you have the all the necessary bolt already that are included in the snake bite kits.
Threads Similar to: Cams???
NSR Comp cams or hot rod cams fallingaway2 2005 - 2010 6 November 12th, 2009 07:14 PM
changing mach1 intake cams with 96-01 cobra cams?? blue03mach1 4V / SVT 19 November 11th, 2009 02:11 PM
lunati cams vs. houston perf. vs. comp cams mylilboostedpony 99-04 0 September 12th, 2009 06:05 PM
