2005 trd tacoma sport
96 cobra cooling issues
i know the 96 cobras have a cooling issue
when sitting in traffic mine likes to creep higher in the temp range so i heard i can go with a 03 cobra t-stat what else can i do that wont kill me on price any kinda fans or what. what about fans from a 5.4 truck will they fit all ideas will help thanks in advance |
1998 mustang cobra
make sure your fans are actually coming on. I heard the CCRM (fan control module) actually goes bad. its in your passenger fenderwell. follow your wires that plug into your fan back into your fender. it has a letter like "R" or something on it, and its a box shape module.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
#3 | |
You can pay for an all aluminum/bigger steeda radiator, kinda pricey, and it doesn't really help much by itself from the people around here who have done it. Careful with what you buy, because some of those 96' steeda radiators have fitting issues with the 96 cobras even though they say they don't. Quickest and cheapest help as you've said is a thermostat. I'd pick up a 160* one, which ever manufacturer you choose.
2003 Mustang GT-SOLD-1996 SVT Cobra -SOLD-
![]() Last edited by crossfire876; June 21st, 2010 at 11:27 PM. |
done deal i appreciate it guys
About how hot does your car get? I've seen mine get to 216*F, what is the normal operating temp for a 96 Cobra? I heard that there was a tsb for 96 cobras put out to correct this problem but I could never find out what exactly was done to correct this problem?
truthfully idk. running down the interstate the needle runs in the middle but sitting in traffic it likes to creep above the mid point and keep creeping up
Okay thanks man.
1998 Mustang Base Model
typically if the temp is fine driving, but goes up at a stop, its a fan issue. Check to make sure your fan is coming on at the right temp and also if it does come on note how much air its drawing through the rad. core. Ive seen many fan motors that were on their way out that still come on but dont draw nearly the amount of air they should. Dont be too quick to condem yours though, it should have 2 fan speeds.
If it doesnt come on check for power and ground at the fan connector when it should be on. |
My car on hot summer days would get excessively hot on the temperature gauge. I took it to Ford for a coolant flush and fill. They flushed it out twice it was that gross. After that I've never had a problem since.
Slowly but surely creeping into the 12's on a stock N/A block...
#11 | |
well first off, aluminum blocks kinda like to be alittle warm.. yes an 04 T stat is a cheap and decent cooling mod. make sure to drill a 1/8th i believe size hole to allow air through so it will open.
[SIGPIC][/SIGPIC] [LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR] [COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR] [COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR] [COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT] |
sooooooooooooooooo wheres the hole suppose to be drilled
If you get the right T stat you won't have to drill a hole. the one from ford has a check valve in it so the air will bleed out of the system. but it's about 10x more expensive than you want to pay.
Threads Similar to: 96 cobra cooling issues
| cooling issues | 5mustang0 | 5.0 Mustangs | 2 | April 25th, 2010 07:55 PM |
| Cooling Issues on '96 Mustang GT | cwilson09 | 96-98 | 2 | September 24th, 2009 07:20 AM |
| cooling issues | superbean | 5.0 Mustangs | 10 | August 3rd, 2009 01:35 PM |
| cooling issues | 232stang | General Tech | 0 | March 11th, 2009 04:20 PM |
| Cooling Issues | rendus688 | V6 Mustangs | 39 | January 31st, 2008 11:09 AM |
