Wheel Hubs
Old June 21st, 2010, 04:51 PM   #1
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
Wheel Hubs
What are signs of bad wheel hubs, i changed my rotors and pads recently and i still get a dam squeaky sound while driving, can a seal bearing on the hubs be bad? thanx for help.
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old June 21st, 2010, 07:26 PM   #2
tbird88tbo's Avatar
1998 Mustang Base Model
tbird88tbo is on a distinguished road
a bad wheel bearing would usually make more of a growling sound then a squeak. If you are getting a rotational squeaking sound i would first check to make sure the backing plates arent hitting the rotors. Did the sound start before or after you changed the brakes?
Old June 21st, 2010, 07:54 PM   #3
T.B.A
well it started a while back den i changed the rotors and pad and u can still hear it, only time its quiet is when im applying breaks
Beauty & The Beast
Old June 21st, 2010, 09:43 PM   #4
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Mine sounded like a horrible drone/hum that got worse as I went faster. I dont think its what you are hearing.
Old June 22nd, 2010, 04:03 PM   #5
T.B.A
it just squeaks dam its so freakn annnoying i chnaged rotors and pads and wen i still heard it fuck wat a kick to the balls..any ideas
Beauty & The Beast
Old June 22nd, 2010, 04:16 PM   #6
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
This may sound strange, but did you use any retainers when you put your rotors back on? A buddy of mine was having problems with a nasty squeek after he replaced his and just could not figure it out. A friend suggested pulling those off. Sure enough, it worked.
Just a simple thought that may be the trick. A lot of times it's the small things like that.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old June 22nd, 2010, 07:48 PM   #7
tbird88tbo's Avatar
Does the noise speed up and slow down with vehicle speed? Make sure you check all the obvious stuff first. Try spinning the wheels with the front end jacked up. You need to pinpoint what side its coming from and if indeed its coming from the front.
Old June 23rd, 2010, 11:08 AM   #8
T.B.A
naw did use retainers...at hight speed i really cant c it its at low speed were i hear it...and it only goes away when i brake, and now when i brake sometimes i hear squeaking as well, dam this sux
Beauty & The Beast
Old June 23rd, 2010, 02:11 PM   #9
97_4V_Sleepa's Avatar
97 GT w/4v Conversion
9.98@127.29
97_4V_Sleepa is on a distinguished road
Send a message via Yahoo to 97_4V_Sleepa Send a message via Skype™ to 97_4V_Sleepa
this may sound like a dumb question, but did you use grease when you puyt them back together? I have to apply a pretty liberal amount of it to the bearings as well as pack it into the bearings. also, did you change the inside and outside pad? again another stupid question. but i have seen guys do worse.
there's a possibility that you didn't wrap the retainer pin around hub nut tight enough and the edge of the pin is touching the grease cap. this makes a extremely high pitched squeak that you wouldn't hear at high speeds.
Let me know if this helped. JB
Originally Posted by ChrisJ View Post
Look at the runners...This is
not a "stock" naturally aspirated intake...
Its for a big breathing engine...
Old June 23rd, 2010, 04:06 PM   #10
2003 SVT Cobra
Intersting story, and this is going to make me look like a COMPLETE FUCKING IDIOT, but yesturday MY car started to make a squel noise. I went to check it out when I got home and two of my lugs were gone and the other three were loose!!!! That could have been bad news! Glad I decided to check it out instead of just ignoring the noise. I felt like a fucking moron. I took the wheels off to paint the calipers and I guess I forgot to completely tighten that last wheel. All three other wheels are fine.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Old June 23rd, 2010, 07:45 PM   #11
T.B.A
dam that coulda been a disaster at hight speeds
Beauty & The Beast
Old June 23rd, 2010, 09:17 PM   #12
2003 gt
5.4 32v on the way
Even at 20mpg losing a tire can be a disaster
Threads Similar to: Wheel Hubs
4x4 Hubs Question.... MustangMatt96GT The Clubhouse 10 October 28th, 2009 06:57 PM
4 In Wheel Iownastang 5.0 Mustangs 15 December 3rd, 2007 10:11 AM
Need Wheel Help Ga_50_foxbody 5.0 Mustangs 5 November 12th, 2007 07:17 PM
front hubs and control arms, anything else while its apart? markush General Tech 0 May 21st, 2007 02:03 PM
