1998 Mustang Cobra
Upgrading Internals
As stated in earlier threads, had an oil pump failure, followed by a knock in the bottom end. So...In process of pulling to motor, and have decided to do a full rebuild. I am running a vortech V2 previously Set at 9psi. I know for sure the motor is running ModMox Rods, not sure on the pistons. Would i be safe going with a comlete rotating assembly kit from ModMax.com? If so would i be best to go with the racing or street set up?
http://www.modmaxracing.com/category_s/3.htm[/URL] I have no intentions of adjusting the boost, but want the motor built stong. Is there any point in doing cams? i would rather not drop an extra grand on doing them, but if the gains are worth it, now is the time. Any imput would be appreciated.
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner |
#2 | |
Being as heavy as a sn95 body is, I would not recommend the race kit. the car would have to be reved to 4000 RPM every time that you want to leave a stoplight, unless you like ULTRA DOUCHE MODE. the Race kit doesnt have the rotating mass to those slow rolling take offs at stoplights, hence race. however the street kit does yet you won't hit 8000 RPM at the track as fast. your choice: Streetability or Horsepower |
1998 mustang cobra
i know cams are expensive, but i wish i had put them in when i did that. im 90 percent sure u cant do the cams with the engine in the car. , my tuner says cams are where u get your big power. id do the cams. when you stroke ur car, u loose some rpm.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
1998 Mustang Cobra
Have been looking at the stoker kits, and i am pretty sure i will go that route, and leave the cams alone. I am also planning on putting in bigger valves while i have it a part. If those are the two biggest changes, will i need to go in for another tune?
Also, kinda a seperate subject from this thread, but im going to drop the tranny, any advice on preventive maintanece i should do while it is out. Has about 100k on it. Thanks for your help!!
MM's Orangest
2004 Mach 1 Mustang
If I had to pick between a stroker kit or cams I'd go with the stroker kit on a FI everytime. The stock cams, doesn't matter what year 96-10 4V, do good work for FI applications. N/A is a different story. You will definitely need to get a tune if you up the boost. Which you should that's the whole reason behind upgrading the rotating assembly right?
Is your tranny auto or stick? You could always replace the clutch and flywheel if you drive a stick. Of course change your fluids.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
Threads Similar to: Upgrading Internals
| Can some explain upgrading my internals | 98cobra4v | 4V / SVT | 10 | June 14th, 2010 09:25 PM |
| upgrading sc | Blk04SVT | 4V / SVT | 22 | November 3rd, 2008 01:16 AM |
| Upgrading to v8 | nickp008 | V6 Mustangs | 9 | January 13th, 2007 06:41 PM |
| Help! (Upgrading Engine Internals) | MicronXD | V6 Mustangs | 5 | December 2nd, 2006 08:48 PM |
| Upgrading Internals | energiesource | 99-04 | 3 | October 2nd, 2006 01:04 AM |
