Wiring Harness
Old June 25th, 2010, 05:30 PM   #1
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Wiring Harness
I picked up a new wiring harness for my motor because the one currently on the car is trash. The car runs ok except for at 1900-2000 RPMs and the car bucks but not all the time. It throws a P0320 code which usually means there is a bad crankshaft positioning sensor. I replaced the sensor but the problem remains. I took it to my tuner and he checked it over and said it's not the tune. He told me it's probably bad wiring which leads to now.
My question is... There are two different harnesses. The smaller harness goes to what appears to be the O2 sensors and everything underneath the car. Is the big harness only on top? The reason I ask is it's pretty hard for me to get under the car because I don't have a huge jack.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old June 25th, 2010, 11:43 PM   #2
14.10 @ 98
Stephen4036 is infamous around these partsStephen4036 is infamous around these partsStephen4036 is infamous around these parts
Send a message via AIM to Stephen4036
hmm well theres an engine harness.. if you have a TR3650 I think** both green O2 plugs are on that...
[SIGPIC][/SIGPIC]
[LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR]
[COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR]
[COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR]
[COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT]
Threads Similar to: Wiring Harness
wiring harness mustangsoldier 5.0 Mustangs 9 March 29th, 2009 07:39 PM
Wiring Harness 98stangv6 The Clubhouse 0 August 22nd, 2008 12:59 AM
wiring harness graystang01 V6 Mustangs 14 April 21st, 2008 03:39 PM
wiring harness hopper 5.0 Mustangs 11 May 13th, 2007 06:53 AM
wiring harness doorvip 2.3 Mustangs 1 December 29th, 2006 03:22 PM
