1998 Mustang Cobra
96-98 Cobra Kenne Bell Guys
Attention all owners of 96-98 cobras with kenne bells or other twin screw superchargers, could you please post some pictures, along with information about install, power numbers, or anything else you can think of.
![]() " When in doubt, go flat out"- Colin McRae MM Cobra Club #76 MM Cleavage Club #14 285 CREW #8 |
Hmmmm.... I have seen alot of things but this is not one of them. Goes back to the whole intake dilemma for the B heads
1998 Mustang Cobra
could u elaborate a bit?
I have never ever seen a kenne bell adaptor intake to put one on a 96-98 4v. this is because the heads are different. The heads are called B heads. the 99-up 4v heads are called C heads. the B heads have 8 intake runners per head whereas the C heads have 4 intake runners per head. The intake is different, so you cant use a 99-up twin screw intake on the B heads. You're better off buying a Cenrifugal SC and an MMR Intake.
#5 | |
9.74@142
The top option in the twinscrew game would be to basically duplicate an 03 cobra set up with a set of 03-05 heads (or atleast 99/01's), complete eaton swap (minus the eaton), and get an 03-04 specific twin screw ........EXPENSIVE! The 2.1, with a post blower methonol kit can also some serious power. For simplicity, its hard to beat a properly set up centri 4v. Dont go too low on the compression (I never suggest less then 9.5:1 on a street driven centri 4.6). My next centri build will be 10:1 ![]() Dont wast your time with a p1sc. Jump right to a d1sc, and if you plan on making over 700 eventually, think about getting an f1 If you like vortech, the S trim will make pretty good power, and do a little better then a p1sc when spun hard, but a T trim is a nice starting point for a be head 4v with a built bottom end. Jump to the YSi if you want more then 700.
#6 | |
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
![]() exactly what this guy said is what i want to do with my B head 4v some day when money allows. dont mess with a roots blower on a B head 4v for the reasons MPE331LX has mentioned above.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
1998 Mustang Cobra
i knew that kenny bell had a specific kit and yes i know it isnt intercooled which makes me sad. i really want a twin screw. I dont care for centri's too much. I autocross my cobra so a good soild torque band that starts low is what im after. Im considering a new engine anyway so maybe just doing the termi swap. Does Ford racings aluminator accept a kenne bell?
![]() " When in doubt, go flat out"- Colin McRae MM Cobra Club #76 MM Cleavage Club #14 285 CREW #8Last edited by brharris777; June 26th, 2010 at 07:20 PM. |
1999 body in white
Yes, they have the lates revision of the terminator heads
If you can't beat 'em...drive a Ford
#9 | |
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 Sold not lost and will never be forgotten. |
1999 body in white
[QUOTE=CammedMysticCobra;3019216] And Centris are the worst for autocross and even for the strip or street they just arnt as effecient, /QUOTE]
Centris more efficient than twin screws 1) Turbo 2)Centri 3)twin-screw 4)roots Twin screw will definately give you the low end grunt you want for the autocross tho.
1998 Mustang Cobra
god i thought this thread died. Im glad it didnt though. Yeah the twin screw is what im set on. thinking maybe i need to swap for c heads. gonna start shopping around. i think i know what i need to do for now. am i goin to need to tune if i just switch the heads out right now?
97GT & 97Snake & 00L
T.B.A
i love my twin screw
![]() 97 Cobra & 00 Lightning Beauty & The Beast I rev next to hybrids so they can hear me kill the environment ![]() MM Cobra Club Member #77 MM Lightning Club Founder |
Priest of the Car Gods
If you're going boost, keep your b-heads if you can.
1998 Mustang Cobra
any particular reason i would want to keep the b heads as opposed to going with c heads so i can get a mammoth blower?
1998 mustang cobra
B heads flow more. little lesss on lower end tq, but they flow like the mississippi up top with boost, and with 4:10's u dont really see a loss down low. heck a friend of mine had 4:56's and that thing screamed!
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
1998 Mustang Cobra
well i have 4.10's and i still feel like im lacking bottom end but i really dont have any other power mods. and i guess im confused on if u can port your heads and still run a supercharger at all with all this talk of port sizing and what not. I also dont really want to run the 2.1. i know that you can make good pressure but its alot of stress on the blower to run alot of boost out of a small supercharger. Im thinking my dream of a 700 hp 600-700 tq twin screw are going by the way side.
aviators also have the same heads as the cobra/mach 1. See if you cant find a wrecked one and buy the motors and then sell the aluminum block etc to make back some of your money
1998 Mustang Cobra
yeah which cobras and i dont have any idea what heads the mach ones have.
all 99 up 4V motors, with the exception of the FR500, have C heads. Pre-98 4V's had B heads. there is an ongoing debate on which ones flow better, but for boosted applications, I will always say stay B heads. If you are dead set on the Twin-screw, and have the money to do it, you could consider water methanol injection. I have it on my 98 with a T-trim, due to the fact that I didn't want the added weight of a Intercooler. It works great and it's adjustable so that if I decide to up the boost, I don't have to worry about buying another intercooler, just buying a different set of jets...kinda like nitrous without the risk of blowing the motor. plus it's like I am running 116 octane all of the time in my car, which means I can pull timing and fuel and make her scream... and she loves to scream.
1998 Mustang Cobra
i dont know much about meth but we cant use any kind of chemical power adder/helper in the SCCA. well if C heads are good enough for terminators then i guess theyre good enough for me. think im just gonna plan on a c head swap. any other info is always appreciated. reps to everyone who helped.
Threads Similar to: 96-98 Cobra Kenne Bell Guys
| See what you guys think my 97 Cobra with Kenne bell | stangersvt97 | 96-98 | 20 | May 28th, 2010 02:00 PM |
| kenne bell 2.1 in a 97 cobra | Keasbey | 4V / SVT | 30 | April 24th, 2010 02:11 PM |
| Kenne Bell on my 97 Cobra. | stangersvt97 | Modular Mustangs | 5 | March 4th, 2010 03:18 AM |
| Kenne Bell Cobra #'s | bbk03gt24 | 4V / SVT | 10 | July 26th, 2009 08:19 AM |
| 03 cobra(kenne bell or whipple) | zincsvtcobra | 4V / SVT | 20 | January 23rd, 2008 11:14 AM |
