96 Cobra throwing code P0307
Old June 27th, 2010, 12:27 PM   #1
1995 Mustang Cobra SVT
bettyn100 is on a distinguished road
I know what the code means (misfire on cylinder 7). I have changed spark plugs, switched plug wires and tested the coil pack. If I erase the code the code comes back at idle as a pending DTC and then will throw the cel while driving.
The freeze data when the pending DTC happened is as follows:
Eng Speed 1226 (I was more than likely revving the engine a bit)
Calc Load 27.5%
Coolant 199
ST FTRM1 -2.3%
LT FTRM1 22.7%
ST FTRM2 10.2%
LT FTRM2 -10.2%
Veh Speed 0
Fuel Sys1 clsd1
Fuel sys2 n/a
Does anyone have any ideas from that information?
Thanks!
Old June 27th, 2010, 03:57 PM   #2
After looking at the old plugs for all 8 cylinders for a lengthy amount of time I can say that some of the plugs are carbon fouled and others are lead (additives i guess) fouled and some are a mixture of the two. The cylinder 7 plug is both carbon and lead fouled.
The only code it's throwing is the P0307. Wouldn't a rich mixture make the car throw an additional code or more?
Threads Similar to: 96 Cobra throwing code P0307
throwing code. HELP MikeD05GT 96-98 29 March 11th, 2009 02:11 PM
So now im throwing a code 93HatchsBFF 99-04 5 January 12th, 2009 12:54 AM
throwing a code Ho_Edge 2005 - 2010 19 January 4th, 2009 10:54 AM
Throwing a code BLK01SS 99-04 10 June 23rd, 2008 12:40 PM
Throwing a P1152 Code... ChrisJ 99-04 9 March 12th, 2007 06:14 PM
