build thread on my 03 cobra!!!!
Old June 27th, 2010, 06:45 PM   #1
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
ok well im going to put pics up of the motor pulled and everything tonite....
cobra had a built motor b4 it got messed up..(20 over,diamond pistons,ported heads)60lb injectors,jlt high boost,kenne bell tb,2.3 whipple 3.25 pulley made 20lbs of boost,off road x pipe with borla stinger catback... compression was built for alot of boost so it actually was to low.. they sent the guy the wrong piston so it made the compression about 8:1....car had this built motor in it when i bought it...i did all the whipple stuff... so same damn day from gettin it back tuned..(driveing it from tuner)...collant hose decides to come off and motor over heated blew head gaskets..also got so hot pistons expanded..when cooled down messed up the block you know... so got motor out now and i will tell you the plans for the built...we figure since its down might as well make it worth it now plus a lil more lol...
new block same rods and crank
20 over manly pistons
going to do compression 9:1
ford gt cams
complete fuel system(got a great deal on one from one of my friends)
bbk longtubes with x pipe
2.3 whipple 20lbs of boost
cold fusion wet kit 125-150 shot
full front upr suspension set up
26 spline input shaft
spec stage 3 clutch( had a ram in it and its just to damn hard)
also going to do a cowl hood
we are shooting for around 650 on pump(not going to be a problem) and high 700 on the bottle on race gas(which isnt going to be a problem either)
also going to powdercoat the valve covers and the front of the motor either red or ford wrinkle blue..car is silver on chrome 18in fr500s
so should be a fun car once we get done with it even though we probably only going to spray it a few times at the texas mile this year and to bust some ass on the street during tx2k11 next year....
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old June 27th, 2010, 10:24 PM   #2
RCCOLA's Avatar
1999 body in white
RCCOLA is on a distinguished road
That's awesome man, good luck with the build. Your horsepower goals should be easily obtained with that KB. Are you using a teksid block now? Or did you find another 03 cobra block?
If you can't beat 'em...drive a Ford
Old June 27th, 2010, 10:26 PM   #3
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Yeah good luck with the build. Post pictures of the carnage when you can.
TT Build in progress.......
Old June 27th, 2010, 10:43 PM   #4
14.10 @ 98
Stephen4036 is infamous around these partsStephen4036 is infamous around these partsStephen4036 is infamous around these parts
Send a message via AIM to Stephen4036
why didnt you shut the car off when the temp gauge went nuts?
[SIGPIC][/SIGPIC]
[LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR]
[COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR]
[COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR]
[COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT]
Old June 28th, 2010, 06:09 AM   #5
slow02gt's Avatar
2002 mustang gt
11.38@119
i did but once your coolant line pops off it happens pretty fast...and i alreafy had a bare iron block thats been sitting in the garage for about a year so im useing that... and its not a weak ass KB its a WHIPPLE man!!!!!!!!!!!!! LOL
Old June 28th, 2010, 01:52 PM   #6
RCCOLA's Avatar
1999 body in white
LOL oh right I misread ur specs. Iron block, as in a GT iron block? I hope you don't split the thing in half!
Old June 28th, 2010, 04:03 PM   #7
slow02gt's Avatar
2002 mustang gt
11.38@119
gt and cobra blocks are the same...
Old June 29th, 2010, 01:28 AM   #8
wicked96gt's Avatar
2001 Mustang GT Bullitt
wicked96gt is on a distinguished road
goodluck with the build! sounds sick!!
Originally Posted by tricep View Post
2001 Mustang GT Bullitt, k&n, BBK longtubes, BBK Catted H-pipe, SLP mufflers, short throw, 3.73s, lowered, built engine, custom blower cams, stage 3 ported heads. 293/300
Old June 29th, 2010, 02:41 PM   #9
RCCOLA's Avatar
1999 body in white
96 to 98(i believe) cobras used a teksid all aluminum block. Then ford switched over to a WAP Block for a while, then for the terminator ford went to a reinforced steel block. All of which from what I understand were not used in the GT.
Old July 1st, 2010, 04:04 PM   #10
slow02gt's Avatar
2002 mustang gt
11.38@119
99-04 gt blocks are iron blocks basically the same as the 03-04 cobra thats what i was trying to say...i know about the alum blocks also guess i should have been more specific..
Old July 2nd, 2010, 11:32 AM   #11
RCCOLA's Avatar
1999 body in white
Ok, but even so, I'm fairly certain that the 03-04 cobra block is much stronger than a GT block. GT blocks can only handle 450 ish horsepower from what I've read.
Old July 2nd, 2010, 12:53 PM   #12
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
No all the Iron blocks can hold more than that. a lot more. Thats why all of your big companies build their short blocks that are for big power using the off the shelf production iron block. Iron blocks are good for a 1000+ all day.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old July 2nd, 2010, 02:16 PM   #13
slow02gt's Avatar
2002 mustang gt
11.38@119
^^^^correct... its the gt internals that suck but thast not going to stop me from makeing close to 500rwhp in mine thru an auto
Old July 2nd, 2010, 07:45 PM   #14
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
500rwhp on stock gt short block?
Military Crew
U.S. Army Aviation
Old July 2nd, 2010, 10:10 PM   #15
slow02gt's Avatar
2002 mustang gt
11.38@119
fuckin right...turbo and turbo cams dont give a shit if it blows
Old July 3rd, 2010, 12:15 AM   #16
tmhiott is on a distinguished road
Old July 3rd, 2010, 01:03 AM   #17
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the 2v's can handle it for a little while, especially if you have cams to go with the set up.
Old July 3rd, 2010, 02:13 PM   #18
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Good luck! It's gonna be an aweful waste of a good iron block when you send the exploded rods thru the sides of it.
Military Crew
U.S. Army Aviation
Old July 3rd, 2010, 02:35 PM   #19
97_4V_Sleepa's Avatar
97 GT w/4v Conversion
9.98@127.29
97_4V_Sleepa is on a distinguished road
Send a message via Yahoo to 97_4V_Sleepa Send a message via Skype™ to 97_4V_Sleepa
Good Luck...You're gonna need it when a rod goes flying out of the side of your fender.
Originally Posted by ChrisJ View Post
Look at the runners...This is
not a "stock" naturally aspirated intake...
Its for a big breathing engine...
Old July 3rd, 2010, 04:07 PM   #20
slow02gt's Avatar
2002 mustang gt
11.38@119
awww it be ok...iron blocks are cheap...in fact got 2 sitting in m shop ready for me to do something with..
Threads Similar to: build thread on my 03 cobra!!!!
My build thread (1982 GT) Lazor05 5.0 Mustangs 91 November 28th, 2010 11:34 PM
build thread culookn Feedback Forum 3 January 10th, 2010 11:53 AM
My Build Thread AMmuslGT 2005 - 2010 2 May 22nd, 2009 09:03 PM
My Build Thread samuel642000 5.0 Mustangs 34 March 19th, 2009 04:29 PM
86 GT Build Thread 68 dlxcoupe 5.0 Mustangs 16 February 4th, 2009 09:46 PM
