2011 September ROTM
2006 Mustang GT
12.04 119
97 centri cobra traction
got a 97 cobra with a vortech with an after cooler running 8 pounds of boost. it has a 3.73 gear. I'm looking for ways to improve my traction with it. it has upper and lower contol arms. lower control arm relocations. it has a 285 35 18 bfg DR on it at the moment and i was thinking on going to the 305 35 18 nitto nt555r. With the drag radials now it spins first pretty bad and half way threw second. I ran a 12.2 with a 2.05 60'. Trying to get it to stick to get it in the high 11's any help or input would be appreciated.
Tony
![]() F1a Procharger 14psi, MMR 900, Tr6060, Remote tuned by Ray Mcclelland = Daily Driver Numbers coming soon 14psi pump - 14psi race - 23psi race - |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
subframe connectors, M/T ET's for the track...555R for the street, what lower control arms? Ford b springs and Strange 10 way shocks/struts
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
slicks, Coil-overs w/ adjustable shocks and a pinion snubber
N/A 4v Guru
2003 Mach 1
+1 on shocks and struts. control arms alone aren't good enough you need springs,shocks, and struts. Do some front suspension as well to help weight transfer to the rear.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
2011 September ROTM
2006 Mustang GT
12.04 119
thanks guys. would it be worth getting the wider tire first or am i wasting my time??
BYAHHHH!
2001 Mustang GT
13.874
you dont need a really wide tire..do thr suspension then tires
1999 body in white
just put a fat guy in the trunk....
If you can't beat 'em...drive a Ford
N/A 4v Guru
2003 Mach 1
width isn't as important as compound. You need a stickier tire more than you need a wider one, couple that with a good rear setup and it'll hook.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way Last edited by Doc8224; July 1st, 2010 at 12:29 PM. |
2003 gt
5.4 32v on the way
lower control arms are relocated? try putting them back to stock location and see how that works for you.
Threads Similar to: 97 centri cobra traction
| New Centri Help !!!!!! | Black Baby II | 2005 - 2010 | 39 | September 7th, 2009 10:32 PM |
| centri vs KB | 01brknGT | 99-04 | 27 | September 26th, 2008 12:56 PM |
| kb or centri? which one?!? | o2gtstang | 99-04 | 38 | September 8th, 2008 01:17 PM |
| 01' cobra traction control issue | windsor351 | 99-04 | 7 | October 3rd, 2007 07:37 PM |
| Which centri? | sorrowfulkiller | General Tech | 13 | August 22nd, 2007 11:20 PM |
