DDM Tuning
Old June 30th, 2010, 08:15 AM   #1
rst1523's Avatar
2003 Mach 1
rst1523 is on a distinguished road
DDM Tuning
has anyone had any prob with ddm tuning and their 9007 hi/lo kit?
Old June 30th, 2010, 04:30 PM   #2
04 Cobra
RC04SVT is on a distinguished road
nope, always had good luck with DDM, but alot of people have not. are you jsut asking around or do you have a kit and are having problems?
04 Redfire Cobra SVT - JLT RAI, Bassani Catted X,Borla Stingers, MGW STS, Tune
08 Mazdaspeed 3 - Too many boltons - SOLD
00 Mustang GT - Too many boltons - Traded
Old June 30th, 2010, 05:48 PM   #3
rst1523's Avatar
2003 Mach 1
having probs. i have one side not firing. i also have 35w 5000k fogs too. i only used the supplied harness that fires the hi/lo. it works when it wants to. not sure if i need to add the extra wiring harness to the hi/lo to solve this. i have 55w in my r6 w/ no prob. so i exchanged the ballests( i went to public schools, i can't spell) and still have the same prob. But, my bike has no prob w/ two 55w hids. the fog lights have no problems, just the head lights. I'm chasing my tail and pissed
Old June 30th, 2010, 10:24 PM   #4
04 Cobra
the 9007 hi/low kit has to use the harness supplied in the kit. if one side is not firing, try swapping ballast to see if it fires then. If it fires, u most likely have a bad ballast. If it still does not fire, but the other side does fire even with the swapped ballast, you most likely have a bad bulb. try this and lmk what you find out.
Also, make sure that when the bulb is going in and out when you hit your hi beam switch the bulb isn't getting stuck half way thru
Old July 1st, 2010, 05:34 PM   #5
rst1523's Avatar
2003 Mach 1
so far it turns out if i turn the head lights on before the fogs i have no prob. but i think i'm going to buy the extra harness
Old July 2nd, 2010, 12:50 AM   #6
04 Cobra
u sure you have everything wired right? the fogs and headlights are totally independent from one another
Old July 2nd, 2010, 12:09 PM   #7
rst1523's Avatar
2003 Mach 1
yeah i know but i think when the hids for the fogs are powering up it drawing too much energy to fire the headlight hids at the same time
Old July 2nd, 2010, 04:07 PM   #8
04 Cobra
HID ballast take less power to run then stock headlights, did you have the issue before?
Old July 3rd, 2010, 03:16 PM   #9
rst1523's Avatar
2003 Mach 1
yeah ever since i put them in. but i just uped the fuse in the harness from 30 to 40 and so far no problems
Old July 5th, 2010, 11:30 AM   #10
04 Cobra
then i have to ask, did u possibly get a 55w kit instead of a 35w? if thats the case you might have issues
Old July 5th, 2010, 11:03 PM   #11
rst1523's Avatar
2003 Mach 1
yeah i got 55w for the headlights and 35w for the fogs. with uping the the fuse to the headlights i have had no problems
Old July 7th, 2010, 01:34 AM   #12
forcefedcobra's Avatar
2003 SVT Cobra
forcefedcobra will become famous soon enough
I have had hell with mine. first set popped the fuse and wouldnt fire right. Got a new harness from them now. while the car had no headlights in........the battery never ran down. now with the new wiring harness (that works this time) the battery drains down in a day or two. I gave up on it and will just buy a battery tender or come up with some way to quick disconnect the harness from the battery.
I buy car mods for the stickers, and I have ALOT of stickers!
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
Threads Similar to: DDM Tuning
DDM Tuning MikeD05GT Vendors 1 August 28th, 2010 11:16 AM
DDM... GTRACER88 99-04 7 March 3rd, 2010 01:57 AM
What is everyones opinion on tuning on dyno or street tuning CammedMysticCobra 4V / SVT 33 November 28th, 2009 10:27 PM
tuning Codeman V6 Mustangs 6 July 15th, 2008 01:28 PM
Tuning bheet 2005 - 2010 2 November 20th, 2007 09:44 PM
