crank bolt torque?
LinkBack (1) Thread Tools
Old June 30th, 2010, 06:15 PM   1 links from elsewhere to this Post. Click to view. #1
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
crank bolt torque?
What does the bolt that screws into the crank and holds the harmonic balancer on get torqued to?
Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount
Old June 30th, 2010, 07:09 PM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
66 ft/lbs, then loosen 1 full turn, then 36 ft/lbs, then tighten additional 90 degrees
Military Crew
U.S. Army Aviation
Apache's Lead The Way
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/172309-crank-bolt-torque.html
crank bolt torque? This thread Refback June 30th, 2010 10:42 PM
Threads Similar to: crank bolt torque?
crank bolt. 07 STROKER 2005 - 2010 16 May 23rd, 2009 03:54 PM
crank bolt moosenuk17 99-04 8 April 18th, 2009 06:04 AM
HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? the1968jeepthing 99-04 2 September 29th, 2008 11:39 PM
New Crank Bolt for UDP's - which one? black07cs 2005 - 2010 3 December 8th, 2007 09:27 PM
