Ford FRPP Aluminum driveshaft install
I'm going to buy this driveshaft in a few days for my 96 Cobra. What else do I need for installation? And about how much do you think Ford will charge me to get it installed at the dealership? Thanks again, guys. Also do I need to tell them to watch the transmission fluid just in case if any leaks out while they are installing it? And does this come with high-performance u-joints? And I have a 31 spline rear axle, right? Pretty much is this just going to be like a bolt on and go?
Ford FRPP 96-04 GT, 96-98 Cobra, and 03-04 Mach1 Aluminum Driveshaft at AmericanMuscle.com - Free Shipping! Last edited by 96SNAKE; July 7th, 2010 at 05:56 AM. |
June 2010 ROTM
2000
Dude,
Its only 4 bolts. You can do this in your driveway in 20 minutes or less. They make a socket that would make the job even easier. I think its a 12 pt. socket. Its called a "Ford Driveshaft Socket" I know Snap-on makes it. I'm sure others make it too. Back the car up on ramps, or jack it up. Little or no fluid will come out the trans. At least none did when I did mine. But literally 4 bolts, out. swap, 4 bolts back in. Done.
HPDE Instructor PCA, HOD, Track Guys, ERME www.RaceCarTowHooks.com My Track Videos http://www.youtube.com/user/Msirlin My Garage page: http://www.moddedmustangs.com/forums...-member-17090/
1998 mustang cobra
nuff said
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
Okay thanks guys.
MM's Orangest
2004 Mach 1 Mustang
And this goes without saying but use stands and don't forget to set the ebrake.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
Thanks, man.
Threads Similar to: Ford FRPP Aluminum driveshaft install
| ford racing aluminum driveshaft | tjames | V6 Mustangs | 36 | July 7th, 2010 09:35 AM |
| Aluminum Driveshaft install done... | SteviGX | 99-04 | 18 | September 14th, 2008 02:09 PM |
| pulleys or frpp aluminum driveshaft for better overall ET? | texasd18e | 99-04 | 24 | April 2nd, 2008 09:39 PM |
