Drivetrain?
Old July 9th, 2010, 12:29 PM   #1
rst1523's Avatar
2003 Mach 1
rst1523 is on a distinguished road
Drivetrain?
ok guys in going to keep my Mach n/a. So prob. no more than 400 to the ground. Will the stock dravetrain hold hold that for daily driving and some drag time?
Old July 9th, 2010, 01:55 PM   #2
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
yep it should hold that h.p with no problem
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old July 9th, 2010, 02:08 PM   #3
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
Of course anytime you add that much power you run the risk of breaking something. Hell, even a bone stock car can snap something if beat on hard enough.
BUT, the axle and tranny should be fine with that much power.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old July 9th, 2010, 04:02 PM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Heh, this is a 3650 we're talking about here. The same tranny that GTs break. My tranny has been going downhill fast since I got the motor rebuild. I have to pray to get it in reverse. And 4th at a high RPM, I won't ever do it again with this tranny. I'd say to beat the living crap out of the tranny but start saving for a T56 or TKO. So when the 3650 does break, you won't be left out in the cold without a car for a long time.
The axles should be fine for everyday driving and even the track. The only time I'd worry about them is a high RPM launch on slicks.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old July 9th, 2010, 04:28 PM   #5
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
will 400whp be hard to attain with a n/a setup?
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old July 9th, 2010, 05:51 PM   #6
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Hard... not really. Costly, yes. Easiest way would probably be a 99/01 Cobra or 03/04 Mach intake with shortened runners and ported, Sullivan, or FR500 intake if you can afford it. A Comp stage 2 cam if you're wanting to keep it street friendly (with all the other things needed for a cam swap, springs ect.) Ported heads and just to make life easier go with a big bore block or a stroker (if you can do both you'll be well over 400). Upgrade your rods and pistons while you have it apart (go with high compression pistons since you're staying N/A).
Lastly, the cheaper parts: exhaust, CAI, you know the bolt-ons. With a cammed 5.0 with intake work you should be right around 400rwhp. If you do a 5.3 BB stroker you could be anywhere from 410 to over 500 depending on how much you do to your car.
Old July 9th, 2010, 10:49 PM   #7
rst1523's Avatar
2003 Mach 1
for right now i have a c&l and mass meter, not sure what on road x-pipe, flow masters, pro 5.0 shifter, i think rear gears, only cause there is a trick flow diff cover. I was told buy a tech at a shop that it feels like i have an upgraded clutch. With that said i hope a tune as well. i bought the car used and now figuring out what i have done already. the gears whine a bit, but i'm going to put 4.10's in it even if they are already in there. and then a dyno tune just to get everything right a/f wise and see how much more i need to go
Old July 9th, 2010, 10:51 PM   #8
rst1523's Avatar
2003 Mach 1
i do like the idea of a 5.3L thought
Old July 9th, 2010, 10:52 PM   #9
rst1523's Avatar
2003 Mach 1
Mach Boy, what do you have done to have 360/345
Old July 10th, 2010, 12:18 AM   #10
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Cams and intake work with full bolt-ons. With the Comp stage 2s I'd be somewhere in the 370s. You really need to have a stroker or 5.0 big bore to get over the 400 hump. You could spend thousands for a set of GT heads/FR500 heads and FR500 intake to make close to 400 or tear down the motor to make at least a 5.0 and be almost guaranteed to get it.
Old July 10th, 2010, 11:51 AM   #11
rst1523's Avatar
2003 Mach 1
i'll prob stroke and cam with full bolt-ons, we will see were that gets me
Old July 10th, 2010, 12:28 PM   #12
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
If you can hold off and save an extra $1000 for a 5.0 block before you stroke it, it will be well worth it.
Old July 10th, 2010, 03:00 PM   #13
manolith's Avatar
11 Mustang GT
Track times coming soon.
manolith will become famous soon enoughmanolith will become famous soon enough
A 3650 can handle 400hp without any issues even 500 and more. Key is no breaks burnouts and a good clutch disengagement. Also don't put to much torque on shifter while you go thru the gears because you will bend the shift forks.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune.
Old July 11th, 2010, 02:40 PM   #14
rst1523's Avatar
2003 Mach 1
yeah i didn't think of that. Good idea
Old July 11th, 2010, 02:42 PM   #15
rst1523's Avatar
2003 Mach 1
i do have a short shifter but i'm not sure if it has stopping points for the arm so i don't eff shit up
Threads Similar to: Drivetrain?
drivetrain help ag11hockey V6 Mustangs 4 June 10th, 2010 02:01 AM
Drivetrain problems S IHI II IB IB Y 99-04 1 September 14th, 2009 01:50 PM
slack in drivetrain justin025 96-98 12 May 7th, 2009 04:19 PM
What would the value of this drivetrain be? Matt300ZXT 5.0 Mustangs 6 November 20th, 2008 09:46 PM
