Crossover coolant plug part#???
I've been having some trouble getting the air out of my coolant system on my 99 dohc. i believe there is supposed to be an o-ring on the plug thats on the crossover tube.
Does anyone know if there's supposed to be an o-ring on that plug - i do see a ridge for an o-ring, also whenever i contact Ford they dont seem to have any clue of what i'm referring to when i say "plug"... Car keeps on overheating about 10-15% above the halfway mark - it never overheats completely but does run a little hot . . . i've been cycling and adding coolant as needed. everytime i take the plug out though, it seems like the coolant is to the top. Any suggestions ? - what started the problem was a hose slipped off and let a lot of air in the system. After a radiator flush, the car now always overheats a little. *** I did change out thermostat and water pump already. Last edited by joojoo84; July 9th, 2010 at 03:36 PM. |
MM's Orangest
2004 Mach 1 Mustang
I took mine to Ford to get the air out. There's a lot of people who do their own stuff that take it to the dealership for a fluid change just because it's so hard to get all of the air out of these DOHCs.
As for the O-ring I don't think there is one. It's just the plug.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
Funny thing - I took the cobra to Ford and they attempted to bleed the system and couldnt get the air out. They just told me to do the same thing I had been doing and it will eventually work itself out...
I've never had a manufacturer tell me something like that . . . its just frustrating. Anyone else know if there is an o-ring on the plug or if they just let the ford dealership bleed the system? ALSO - it seems like coolant is leaking out of my plug a little bit. None of the threads are messed up and i make sure its pretty snug - anyone have any idea where i can get another plug? Last edited by joojoo84; July 9th, 2010 at 04:25 PM. |
1998 mustang cobra
i dont think there is an 0-ring. i didnt' see one when i had mine out last. i let mine run and loosen it a lil and a bunch of bubbles keep coming out. then i drive the car again and stop and bleed it out again. i repeat the process over and over again. it does take a while to get all of it out.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
MM's Orangest
2004 Mach 1 Mustang
You could have a bad cap for your reservoir. You can give Tousley Ford a call. They usually have the best dealership price you can get.
replaced the cap on my resevoir as well . . .
ok . . . so, in conclusion, the cobra now only overheats when cruising at low speeds (35 mph and under)
could this be radiator possibly? |
It is ... At idle anyways...the condenser fins are really messed up and i think airflow is gettin blocked to the radiator (which is already a 10 year old stock rad)
Ordering an 03-04 cobra radiator. I'm also gonna pick up a new coolant reservoir (probably canton or black moroso) also with low temp t-stat.
Anybody have suggestions on coolant reservoir and also on coolant panel? |
Here is the part# for crossover plug:
F3LY-8A500-A It is a Lincoln part number and it DOES come with oring as well. |
Threads Similar to: Crossover coolant plug part#???
| coolant in spark plug well | eddy21x | 99-04 | 3 | January 11th, 2010 11:11 PM |
| coolant crossover sensors? | 98Cobra_sleeper | 4V / SVT | 5 | September 6th, 2009 10:53 AM |
| water crossover on intake manifold leaking coolant | hardhitter | 99-04 | 10 | January 5th, 2009 02:39 AM |
| coolant drain plug | Buttaz | V6 Mustangs | 2 | July 25th, 2007 01:01 PM |
| coolant crossover tube | daleboeski | 96-98 | 5 | August 13th, 2006 06:52 PM |
