could use some help and information on an engine build - Page 2
Old July 13th, 2010, 09:16 PM   #21
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Yeah you don't have a terminator setup. You would have to do an "eaton swap" minus the eaton.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old July 13th, 2010, 09:32 PM   #22
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Originally Posted by brharris777 View Post
Um any reason i cant use the mammoth kit for the terminator?
For starters you have B heads, and the lower manifold needed requires C heads. If you swap over to C heads, you could just copy any setup you like on the termies.
Old July 13th, 2010, 09:42 PM   #23
1997 Thunderbird
14.06 @89.53 needs tuned
Dirtyd0g is on a distinguished road
I looked into that kit and I agree with that, you'll need terminator heads to use the terminator kit.
Alan
Old July 14th, 2010, 12:10 AM   #24
brharris777's Avatar
1998 Mustang Cobra
brharris777 will become famous soon enoughbrharris777 will become famous soon enough
i may need to call kenne bell on this one but they a new lower intake and does this intake accept their other superchargers?
" When in doubt, go flat out"- Colin McRae
MM Cobra Club #76
MM Cleavage Club #14
285 CREW #8
Old July 14th, 2010, 12:47 AM   #25
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Do exactly what you said. Call KB and tell them your goals. They will point you in the right direction.
Old July 14th, 2010, 12:53 AM   #26
1998 Mustang Cobra
ok blower, call KB
heads cams??? still up in the air a bit. im making a big shopping list. would like to upgrade the lubrication system and livernois makes alot of of them but im not sure if theyre gimmicks or if its all legit. New - Livernois Motorsports - Browsing Store also things like head studs and other fasteners should also be replaced i assume. Ive heard that the head bolts are toque to yield and should never be reused on the 4v.
MM Cobra Club #76
285 CREW #8
Old July 14th, 2010, 06:24 PM   #27
1998 Mustang Cobra
just got off the phone with KB they said the lower intake for the 98 cobra only accepts the 2.1. soooooooo should i maybe consider finding a set of terminator heads?
MM Cobra Club #76
285 CREW #8
Old July 14th, 2010, 07:03 PM   #28
1997 Thunderbird
All modular head bolts are TTY and should be replaced once torqued and removed, unless you use arp head studs.
Alan
Old July 14th, 2010, 08:08 PM   #29
1998 Mustang Cobra
Alan
as i thought.
MM Cobra Club #76
285 CREW #8
Old July 14th, 2010, 09:24 PM   #30
2003 gt
5.4 32v on the way
You dont have to get termi heads, any 4v C heads from 99-05 have the same intake port. They made slight adjustments over time and newer heads flow better of course, but if you send them off to get ported the year matters less. If you are going to go out of your way for heads, find 04/05 heads as they have 9 threads per spark plug. The thing with C heads is when you start getting picky they start getting pricy. If you go with 04 C heads that are in good shape, expect to spend ~600-800, however older C heads can be had for 300 or so. If I were you id look into getting an older set of C heads, then sending them out for a stage 2 porting, and throw your cobra cams in. Porting heads will cost about the same as getting cams, its just easier to swap cams down the road vs sending out your heads after your motor is done.
Old July 14th, 2010, 10:13 PM   #31
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
hello sir
u dont need a stroker kit or cams to hit 700rwhp with ur 4v. just get a good rotating assembly (forged, blower friendly around 9.5comp) and port those B heads. i have a built shortblock, ported heads and stock cams, and with 15lbs of boost i make the power ur looking for. BUUUT realize u need a bigger fuel system, stronger transmission, and rear end.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old July 15th, 2010, 12:14 AM   #32
1998 Mustang Cobra
Originally Posted by 98Cobra_sleeper View Post
hello sir
could u possibly PM me with a parts list and some specs of your build, along with what blower your using.
MM Cobra Club #76
285 CREW #8
Threads Similar to: could use some help and information on an engine build
Engine Build poranksta 99-04 39 July 3rd, 2010 09:49 PM
Engine build 302Boss 5.0 Mustangs 19 June 10th, 2010 10:40 PM
Engine build?? Ijuswan2gofast 5.0 Mustangs 6 April 17th, 2010 05:11 PM
engine build... Willy Mo 99-04 6 January 10th, 2010 04:21 PM
Engine Build Up or Engine Replacement... OcOnnor220 99-04 8 July 27th, 2008 03:54 PM
