1998 Mustang Cobra
could use some help and information on an engine build
The engine in my 98 cobra has 135000 miles on it. I am planning on a new engine or having this one rebuilt. ive heard things about 98 cobra blocks being an amazing place to start but i may be mistaken. Im looking at somthing from livernois, either a rotating assembly or whole motor and my end goal is to make anywhere between 500 and 600 horse. Im looking at going compund boost and still want the car to be streetable. Anyone with any info please help me out.
![]() " When in doubt, go flat out"- Colin McRae MM Cobra Club #76 MM Cleavage Club #14 285 CREW #8 |
MM's Orangest
2004 Mach 1 Mustang
You have a teksid aluminum block. They are as strong as they come from the factory.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
1998 Mustang Cobra
thats what i had read here and there but i didnt wanna go spouting off. capabilities?
N/A 4v Guru
2003 Mach 1
They will hold over a thousand. I also don't think it's really worth wasting the money for compound boost if you are just going for 500-600. You can get that on a good motor with either a blower or turbo's no need for both. If you can afford the down time then just build using your block it's much lighter than the Iron block and it will hold it all.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
#5 | |
1998 Mustang Cobra
MM's Orangest
2004 Mach 1 Mustang
If you're going to get a new rotating assembly get a stroker kit. It will help you reach your numbers better than compound boost. Compound boost isn't efficient. It's just got a wow factor to it and tells other people that you've got money. You can make more power on a turbo setup. The supercharger holds the turbos back.
I don't know why you couldn't reach your goals with stock cams and a stroker with a big enough supercharger.
1998 Mustang Cobra
REALLY!!!!!!!!!!!! wow here i was thinking id have to do somthing crazy and make this a very unstreetable car and spend alot of money on heads and cams. obviously it would all help but wow that would be great if i could get my numbers with a new rotating assembly and a blower. which blower do ya spose would be the best for me?
2003 gt
5.4 32v on the way
You should get rods and pistons, maybe look into C heads and throw your cams in them.
1998 Mustang Cobra
im looking at livernois' stroker rotating assembly. their stage 3 heads are 330 intake and 275 exhaust. how does the c head compare.
MM's Orangest
2004 Mach 1 Mustang
Just about every supercharger except the Cobra Eaton is capable of the numbers you want. The supercharger isn't the hurdle. It's building a motor that can hold the power you want to throw at it. Don't forget that you'll have to upgrade other things to hold that power other than the engine.
2003 SVT Cobra
Plenty of street driven cars making 700 to the wheels. Also, compound boost is something I wouldn't really worry about for your goal.
A twin turbo kit would help you make that power. As far as superchargers, the first place I would look is at a F1-A. Those bastards make some BIG power. But a large Kenne Bell will get you close to your goal also.
![]() 03 Cobra-Slow 02 SS, 00 Z/28-Gone Rest In Peace Travis Billings
Zoolander
04 Cobra #2260/3768 1/820
Lol if you can get the Mammoth on your block then you can def make the power.
Depends on how you want the boost to be made too. Do you want it down low or more up high? Also the supercharger you choose does make a difference Whipples can make great power, but put the stress on the engine Kenne Bell can make great power, but puts the stress on the blower Centrifigal superchargers can also make great power, but won't have the torque down low like a whipple or kenne bell. |
#13 | |
All you really need are some manley rods and pistons. You should be able to get some used 2003-04 cobra h beams for pretty cheap. Add some manley pistons, and you are off! If you are going with a centrifigual blower, keep the compression ratio high (9.5 to 10.5) For a screw/roots or a turbo you need a lower compression ratio. Your b heads are just fine. No use in purchasing C heads...the difference (stock of course) is less than 15 hp n/a
1998 Mustang Cobra
i'm liking kenne bell as far as superchargers go. i want a good flat torque band thats fairly neutral in the hi to low spectrum.
#15 | |
Heres my link of a very similar question from a memeber who was building 2004 Mach and was wondering what would be better for his build concerning what type of set up to go with to get the best efficency and all the questions you were asking. Looks like I'm going with a Large Twin Screw. And heres a link on the history and explation to the Teksid block which is the best block ever sold by Ford ever. Lincoln Mark VIII
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 Sold not lost and will never be forgotten. Last edited by CammedMysticCobra; July 13th, 2010 at 02:04 PM. |
1998 Mustang Cobra
hey thank you.
1998 Mustang Cobra
ok so block, check.
rotating assembly, I need a new rotating assembly anyway or at least pistons and rods so wouldnt a stroker kit be the best way to go? heads and bumpsticks, comps XE-R 106400 cams seem like they would be good for my application, as far as heads im still clueless. and according to kenne bell if my engine is as strong as an 03-04 i can use the mammoth and make 700 easy. '03-'04 Cobra 4.6 4V 2.8L Competition Supercharger
1997 Thunderbird
14.06 @89.53 needs tuned
Tip, MarkVIII blocks are the same if not better and easier to get.
Do yourself a favor and use the Mahle pistons, for one they don't have to run the high clearance so they don't knock when they are cold, for 2 they are the best deal out there for forged pistons. I also prefer the Teksid block crank because it is nodular and lighter. Using 03/04 cobra rods with that setup will make an easy to balance setup. Tungsten is expensive if you have to buy it for heavy pistons or rods to balance out. Alan |
#19 | |
1998 Mustang Cobra
Um any reason i cant use the mammoth kit for the terminator?
1997 Thunderbird
Threads Similar to: could use some help and information on an engine build
| Engine Build | poranksta | 99-04 | 39 | July 3rd, 2010 09:49 PM |
| Engine build | 302Boss | 5.0 Mustangs | 19 | June 10th, 2010 10:40 PM |
| Engine build?? | Ijuswan2gofast | 5.0 Mustangs | 6 | April 17th, 2010 05:11 PM |
| engine build... | Willy Mo | 99-04 | 6 | January 10th, 2010 04:21 PM |
| Engine Build Up or Engine Replacement... | OcOnnor220 | 99-04 | 8 | July 27th, 2008 03:54 PM |
