2001 Mustang Cobra
Rear Diff Fluid Help
i have an 01 cobra and im going to be doing a gear install and i need to know what fluid to run. I plan on using royal purple but im not sure what type. I was on www.motorcraftservice.com and looked at the svt owners guide and it says 80w-90 but if you look at the general manual it says 80w-90 is for 7.5 and 75w140 for 8.8 rears. Which is correct? the 03-04s call for 74w140. It also says synthetic is royal purple a synthetic? and woudl still need friction modifier?
I think the 03/04 rears are a little
different from the 01's correct??
2 red Notches 1 70mm Turbo'd 1 Si-Trim'd Turbo is FS/TR: http://www.californiafords.com/ubb/u...c;f=5;t=090443 |
2001 Mustang Cobra
as far as im aware there the same besides different gears from factory the 99 i believe is the different setup
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I have always ran 75w140.
2003 Mach1
13.615
75w140 is what i will be running when i do my gear swap next week.
Use friction modifier even with royal purple. |
Threads Similar to: Rear Diff Fluid Help
| Diff. Fluid Change Time!!! | I8ACMRO | 99-04 | 25 | May 12th, 2010 09:56 PM |
| rear diff fluid... | workinprogress | 99-04 | 16 | March 14th, 2008 07:13 PM |
| Tranny And Diff Fluid | armymike63b | 99-04 | 4 | November 14th, 2007 01:30 PM |
| how much trans and diff fluid | militarygt | General Tech | 8 | July 23rd, 2006 01:08 AM |
