#21 |
2004 Mach 1
They aren't talking about getting a Terminator, they're talking about putting the engine and tranny of one into his GT.
#22 | |
11 Mustang GT
Track times coming soon.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune. |
#23 |
Priest of the Car Gods
This. SRA has a HUGE advantage over IRS in that it has an effective dynamic negative camber gain under compression. You need fancy pants SLA-style IRS (i.e. not the Cobra setup) to replicate the ability of the SRA to keep the wheels flat on the pavement.
#24 | |
2003 Mustang SVT Cobra
![]() MM Cobra Club member #20 |
#25 |
2004 Mach 1
Oh yeah I know but he was saying just a "few" suspension upgrades and saying his cobra with a few upgrades was better. I mean obviously right off the bat the cobra will handle better and even a "few" upgrades might not mean it'll be able to out-handle an IRS.
#26 |
sorry misunderstood... my apoligies...
#27 |
2004 Mach 1
The teskid block is easily one of the strongest blocks Ford makes, that's not an opinion, it's a fact. Handling it will take more than a "few" upgrades for the SRA to handle like/better than IRS so I can understand that.
#28 |
From what i understand the iron block will handle more boost... i may be mistaken
#29 |
It might, but it's at power levels that most people never build to. Everything I've ever heard and read is that a teskid block with proper internals is good to 4 digit horsepower. Ford went to the iron block for the Termies because that was after they had stopped using the Teskid in favor of the WAP block, and the WAPs wouldn't handle what Ford wanted to do with the Terminator.
#30 |
2001 Cobra
14.2@102 (I suck)
So teskid is the best block, Stock vs stock IRS is better? I'll probably be getting a 96-98 due to money restraints, although I saw a black 99 for only $8500. no way am I getting a Termie....for the money I would rather get a 3-valve
![]() of the SN95 cobra's I have heard 97 is best? somthing about new style fuel system in 98 that did handle as much boost? I'm for sure not boosting my car though so thats not in consideration. you guys have so much damn info keep it comin!
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
#31 |
I definitely prefer the aesthetics of the '96-98. One of the best looking modern Mustangs IMO.
96 and 97 have the dash clock, and have a retun-style fuel system. 98 I hear different things... that it was sill return style, that it was the first year for returnless, and that it had some wonky one-off setup. Hell, I *had* a '98 and couldn't tell you what it had, as I never did anything that required upgrading the fuel system. EDIT: The more I think about it, the more certain I am that '99 was the first year of returnless. One thing to watch for on the b-ports is the steering wheel. Sounds lame, but the leather on those things goes to trash pretty quickly under sunlight. I replaced mine with an FR500 wheel, and it was worth every penny for the better wheel. You have the typical issue with T45s, in that they don't have internal shift stops, so you'll want to get an aftermarket shifter on there ASAP. I had a tri-ax, I'd like to try the MGW. One really nice thing about the tri-ax is that it uses the stock shift handle mounting, so if you're weird like me and prefer a LONGER handle that you can actually reach without having your seat so far forward you eat the steering wheel, you can use the stock shift lever on the tri-ax base (that was the set-up I ended up preferring).
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Last edited by ReverendDexter; July 16th, 2010 at 11:56 AM. |
#32 |
2001 Cobra
14.2@102 (I suck)
Sounds good, my friend. there is a white one I have been looking at that has 113k miles, with a new engine with 50k. Is that something I should walk away from?
edit: might as well post the link http://sfbay.craigslist.org/sfc/cto/1835163912.html
#33 | |
2001 Cobra
14.2@102 (I suck)
#34 |
Maybe a stock one, but there's guys turning 10s, and maybe even 9s on built IRSs. My understanding is the half-shafts are the weak-point, and you can get significantly stouter ones if you know you're gonna take it to the strip.
#35 |
\/ Hidden Bewbs \/
01 Cobra Vert
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
As long as you keep the engine mostly stock and don't add any huge power, I doubt you'll destroy the rear end with the IRS. Mine's been launched plenty of times decently hard.
![]() MM Cobra Club #66 |
Threads Similar to: Advice for buying a cobra
| Need Some Advice on Selling 03 GT and buying 96-98 SVT Cobra | crossfire876 | Modular Mustangs | 3 | June 13th, 2010 04:37 PM |
| Buying some things need advice. | Rich J | V6 Mustangs | 41 | March 5th, 2010 08:43 PM |
| Might be buying an 04 GT Vert, need advice. | icipher | 99-04 | 8 | February 23rd, 2010 05:46 PM |
| Advice On Buying Used '05 | ItalianStallion | V6 Mustangs | 24 | November 29th, 2007 10:40 PM |
| Advice on buying | Buegie | V6 Mustangs | 22 | January 3rd, 2007 11:20 PM |
