Advice for buying a cobra
Old July 14th, 2010, 04:06 PM   #1
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
Hello my 4-valve amigos. I've had my '96 GT for about a year and a half now, loved it, but now I'm thinking I am wanting a cobra. Let's face it, 4 > 2. Anyways, I was just wandering if there are any common problems among SN95 cobras that I should be aware of, or even if there is a certain year that is best. My price range is around 8 grand (got a good job this summer) so its most likely going to be a 96-98, possible 99 or 01 if there is one for cheap. Any input at all will be greatly appreciated. thanks, guys.
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old July 14th, 2010, 04:33 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Really depends on what you want.
'96-98 are b-ports, which have less low end, but are better heads for putting boost to.
'99 is the first year of the C-port heads and IRS, they were known to be down on power compared to advertised, and the IRS is the weakest unit (27 spline, weak halfshafts).
'01 has an improved IRS, but not quite as good as the '03/04 unit. Early '01s still have the Teskid block, later have the WAP block which is considerably weaker. Early '01s still have T45s, later have 3650s.
O o
/¯/______________________
\_\
Old July 14th, 2010, 04:39 PM   #3
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
My plans involve some tastefull bolt-on's and suspension. Maybe coilovers...but probably not. Eventually I might add some chasis stiffening components, maybe. Definitely no boost or NOS or anything intense like that. The biggest thing I might do, because I hear it's kind of straightforward, is swap IRS to solid rear axle, but I have a feeling I will never get that involve. I'm not looking for a street monster or a corner carver or awesome drag racer, just a DD that is a whole lot of fun to take cruising
Old July 14th, 2010, 05:05 PM   #4
If that's the case, I wouldn't bother with an SRA swap if you get a New Edge. Just do a light build on the IRS; it has much better ride quality/street manners.
I'd definitely recommend SFCs on whatever you get, no matter how you're using it.
O o
\_\
Old July 14th, 2010, 05:05 PM   #5
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
The 96-98 have a solid axle already. 99 is when they started the IRS.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old July 14th, 2010, 05:32 PM   #6
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
got it, thanks. and thanks again Rev for your vast bank of knowledge. It's not that I WANT solid rear axle, its just that I heard Mustang IRS wasn't the best because it was tailored to fit the same body as solid axle. Does the IRS still allow for some powerslides every now and then?
Old July 14th, 2010, 07:35 PM   #7
termin8er03's Avatar
2003 Mustang SVT Cobra
termin8er03 is on a distinguished road
I have level five half shafts and irs brace which makes a word of diff!!! The cheaper way to go and strong is the straight axle. I wanted to keep my cobra reasonably original far as structure of the car. If u dont care about that straight axle all the way. I have about 1500 in my independent...
<img src=http://i967.photobucket.com/albums/ae159/Termin8or03/1279056717-1-1-1.jpg border=0 alt= />
MM Cobra Club member #20
Old July 15th, 2010, 09:18 AM   #8
My understanding is that once you put a diff brace on it and replace the IRS subframe bushings, it's actually fairly stout.
I'd talk to FTBR (Full Tilt Boogie Racing Homepage) about your plans and see what they say.
O o
\_\
Old July 15th, 2010, 10:30 AM   #9
manolith's Avatar
11 Mustang GT
Track times coming soon.
manolith will become famous soon enoughmanolith will become famous soon enough
For that money you could get the heart of a terminator in your gt. Can't beat that.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune.
Old July 15th, 2010, 10:35 AM   #10
Unless you're into that whole "turning" thing. Termie motors are HEAVY and would make the car even more front-heavy than it already is.
O o
\_\
Old July 15th, 2010, 10:39 AM   #11
manolith's Avatar
11 Mustang GT
Horsepower laughs at weight all day long.
Old July 15th, 2010, 10:44 AM   #12
2003 SVT Cobra
I don't think weight is the problem so much as weight distribution.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Old July 15th, 2010, 11:00 AM   #13
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
get the 96-98 cobra, sexi as hell...wit 8k u can find yourself a nice one for sure
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old July 15th, 2010, 11:08 AM   #14
Uh-huh. That's why sportbikes are so slow, right? Psh, 180hp. Most Hondas have more than that, and look how slow they are!
O o
\_\
Old July 15th, 2010, 12:06 PM   #15
manolith's Avatar
11 Mustang GT
Talk about taking it to extremes. But if you want to take it that far give me a 1000hp 4500lbs bugatti veyron and lets race your 200hp bike.
Old July 15th, 2010, 12:33 PM   #16
Veyron does the quarter in 10.8 @ 140
Kawasaki ZX-12R 10.06 sec @ 142 mph
Suzuki GSX1300R 9.86 sec @ 145 mph
O o
\_\
Old July 15th, 2010, 02:15 PM   #17
manolith's Avatar
11 Mustang GT
0 to 200....
If you will compare bikes to cars then a z06 is garbage because its slower than a bike. We are talking about cars here. You really think than an extra 85lbs up front that the terminator has will impact performance much. A battery relocation kit and fiberglass hood will almost get rid of that extra weight and you skill uavw another 30 lbs to drop with a tubular k member.
If we were talking about a ferrari then I would have to agree with you tuat 85 lbs is a big deal but on a mustang.. comon ... this things have so much crap that can be dumped for weight reduction.
Old July 15th, 2010, 03:30 PM   #18
0 to 200....
Not really as cars easily outhandle bikes. But when you're talking race on this board (much to my chagrin) people are almost always talking about 1/4 mile. You want to talk 0-200? Then you don't want a bike - at those speeds aerodynamic resistance plays a much bigger role than weight.
Absolutely. We're talking 85 lbs on the nose of an already front heavy car. Ford thought so, too, with the N/A Cobras they elected to use an aluminum block to make up for the added weight of the DOHC heads. The saving grace of a Terminator is that it has all the extra weight of the IRS out back to try and balance it out, but even then they're still very front-heavy.
Now, if all you care about is straight line, it's not as big of a deal, because you don't care about the polar inertia of the car (it is more mass you have to accelerate, though, and that's always bad. 85 lbs is almost a passenger). If you're doing top speed, you don't care, because wind resistance is a much bigger force against you than mass.
And much like the V6 vs V8 argument, if you had started without that extra 85 lbs, you could do the same things and be much better off.
Oh, so a Ferrari with 400hp can feel the difference, but a Mustang with 400hp can't? That's just asinine. There's nothing magical about Ferraris other than how they convince their customers that it really is worth $100k just for the prancing pony on the hood.
O o
\_\
Old July 15th, 2010, 03:49 PM   #19
My car is a mild to upper horsepower car and no I don't care for the weight of and iron block but in boosted applications the aluminum block tends to be weaker. Yes termys are heavier but not enough to justify not gettin one. I had an 03 mach 1 with a few suspention mods and my termy has a few also and I'll take the termy any day hands down!
Old July 15th, 2010, 05:03 PM   #20
04MachOne's Avatar
2004 Mach 1
04MachOne is on a distinguished road
Are you comparing the handling of an SRA Mach with a "few suspension mods" to an IRS termi with a "few suspension mods"? I'd hope the termi can out handle the SRA Mach.
And you are telling us you'd take your iron block out of your termi over the aluminum teksid block out of the Mach?
Threads Similar to: Advice for buying a cobra
Need Some Advice on Selling 03 GT and buying 96-98 SVT Cobra crossfire876 Modular Mustangs 3 June 13th, 2010 04:37 PM
Buying some things need advice. Rich J V6 Mustangs 41 March 5th, 2010 08:43 PM
Might be buying an 04 GT Vert, need advice. icipher 99-04 8 February 23rd, 2010 05:46 PM
Advice On Buying Used '05 ItalianStallion V6 Mustangs 24 November 29th, 2007 10:40 PM
Advice on buying Buegie V6 Mustangs 22 January 3rd, 2007 11:20 PM
