Nitrous hound?
Old July 20th, 2010, 12:42 PM   #1
majorownage is on a distinguished road
Nitrous hound?
Hey, I was thinking, how cool would it be to have a 700rwhp 4v 4.6L nitrous car?
Lots of people have done the supercharger/turbo route, and I want to be different!
Im thinking some 80lb injectors would be a must, along with cobra crank, manley i/h beams, etc.
I just think I would be crazy to have a 2 200 shot systems.
Your thoughts? Has anyone done this much nitrous on a 4.6 before?
Old July 20th, 2010, 02:06 PM   #2
manolith's Avatar
11 Mustang GT
Track times coming soon.
manolith will become famous soon enoughmanolith will become famous soon enough
It could be done but its risky. Nitrous loves to melt pistons. Is a dangerous setup.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune.
Old July 20th, 2010, 02:23 PM   #3
When correctly set up, nitrous can be very safe.
The top three killers are:
1. Hitting the stock rpm limiter.
The stock rev limiter is governed by fuel shut off (poof goes the engine)
2. Having the solenoid stuck open
There has gotta be a filter for the NOS before it enters the solenoid so particulates to not wedge the solenoid open.
3. Backfire
Especially with 4.6's the intakes love to pool nitrous/gas mix. Wet nitrous is not good for mod motors!
I am looking for someone with experience with heavy shots of nitrous...hello anybody?
Old July 20th, 2010, 02:39 PM   #4
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
I have seen people run 2 stage setups on mod motors. Build it properly, run nitrous controllers, and you will be fine.
The pooling comment you make will not happen with a properly installed kit, that is run at proper RPM's. I would not run anything other then a wet kit when you are tlking about having your fuel system make up for the insane amount of nitrous you want to run.
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old July 20th, 2010, 02:52 PM   #5
manolith's Avatar
11 Mustang GT
You dont have to worry about gas pooling because of your 300shot you will do direct injection. I was giving just an opinion. I run nitrous without any issues but alot of drag racing guys go with turbos and blowers because nitrous breaks shit.
Old July 20th, 2010, 02:56 PM   #6
01 Cobra Vert
Nov 09/10 ROTM!
I know more guys building big nitrous motors then I do big turbo motors. Nitrous is the power adder of choice it seems in central Gerogia.
And properly tuned and applied, nitrous breaks the same amount of shit as turbos and superchargers.
Military Crew E5
Old July 20th, 2010, 05:44 PM   #7
Why a wet system? I think you would have more control with a large set of injectors....
Old July 20th, 2010, 06:10 PM   #8
86er's Avatar
big shots and dry is asking for trouble.
You have a safer control over a large shot with a wet system, seperate fuel supply with the nitrous. Car goes lean, turn off the nitrous and the car is still fine,
go lean on a dry shot and the whole motor is going lean.
your best bet would be a 10 or 11:1 motor with really good internals, and a 300 shot, on a fogger with a progressive kit and a window switch that would put you really close to a 700 mark at the tires.
Just a truck
Old July 20th, 2010, 06:36 PM   #9
CammedMysticCobra's Avatar
Mustang MystiqueCobra2004
CammedMysticCobra can only hope to improve
Send a message via AIM to CammedMysticCobra
I concor with 86er's stament if you really want to run N20 shot or you can also run a 2 stage 150 shot with the window switch which would pull just as hard this will give you the ability to not run the second shot if you dont need it. I have always hated nitrous because of the fact the power isnt always there in the motor its in a bottle and second the bottle is done your ability to run anyone is also done and than you have to go a fill up the bottle every time its done. You will also have to run 2 20lb bottles if you want to have more than 5 to 7 good runs. And dont forget your going to need suspension,tires and transmission to hold the power.
Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne
http://www.youtube.com/user/MysticCobra04
Sold not lost and will never be forgotten.
Old July 20th, 2010, 07:47 PM   #10
86er's Avatar
two ten lb bottles got me 7-10 passes a night on a 275 shot
Just a truck
Old July 20th, 2010, 10:25 PM   #11
Yea this will be a mostly strip car.
When people see a 4.6 with out a turbo/super they are like, meh 4.6's suck w/o FI
However, a 4.6 nitroused to kingdom come would be kinda surprising and different.
I have seen a lotta whippled cobras/ twin turbos etc. I have never seen something larger than a 200 shot on a 4.6...should be eye opening =)
Threads Similar to: Nitrous hound?
Getting Nitrous and new clutch installed...have a question about nitrous VanWilder 2005 - 2010 2 May 13th, 2010 11:52 AM
Nitrous is here. C0BRAK1LL3R 99-04 17 May 30th, 2009 03:11 PM
Nitrous on a V6? sudbury33 General Tech 1 May 27th, 2009 03:35 AM
nitrous kreil45 5.0 Mustangs 7 June 17th, 2008 02:47 PM
