suspension alignment question...caster? help
i gotta 96 cobra that is lowered..was when i bought it..the front tires were crap...so I bought new rear tires and put olld rears on front..got alignemnt..shortly after.and continues to run shaky....and pull to the right.. I notice my caster is off...heres the spec after alignment...
i hesitate to p ut new front tires on till figuring out what to do..i might be raising it back to stock if that will fix this..let me know if tihs will fix if back to stock..i dont want caster camber plates...and have a guy that will swap me stock springs... my specs after alignment front toe .15 left .15 righ rear toe .00 left. -0.15 (off? said not adjustable? caster front left . 4.1 right 3.4 ( said need plates to adjust) is that too much? camber front left -1.2 right -1.0 rear left -0.1 right -0.3 total toe .30 thrust angle 0.1 this make sense to anyone...my front tires arent the greatest and do have wear ...before alignment..i just wanna get this fix and put new tires up front...an dont know ehre to start...no caster camber plates will i buy...but will put stock springs back on.... |
Zoolander
04 Cobra #2260/3768 1/820
why do you not want caster and camber plates? They can help in the long run with whatever kind of suspension setup you want by creating more room for adjustment.
Threads Similar to: suspension alignment question...caster? help
| MM Caster/Camber Alignment Reccomendations | dannyboy281 | 99-04 | 21 | July 23rd, 2010 01:47 PM |
| alignment question | adrenaline=lifeline | 99-04 | 10 | March 15th, 2010 10:31 PM |
| Home alignment, how to measure caster? | ReverendDexter | The Clubhouse | 4 | July 19th, 2009 07:57 AM |
| Alignment Question | Zurdo03GT | 99-04 | 2 | July 7th, 2008 08:19 PM |
| alignment question | B0B | 99-04 | 4 | June 21st, 2007 02:00 AM |
