1998 Mustang Cobra
Need Help on Pulling my DOCH
I have everything off of the motor except for the headers. Disconnected the tranny bolts last night, but couldnt get the starter off(got 2 of the 3 bolts). I have BBK LT's an now think they will hit the K member when we try and hoist the motor. Can someone that has done this before give me some advice. I really really dont want to drop the k member, but cant get to the headers without doing it. Thanks
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner |
2003 gt
5.4 32v on the way
Have you put any thought into dropping the k member and motor out through the bottom and lift the front of the car up?
1998 mustang cobra
thats how i had to do it, drop the motor out through the bottom. ull never clear with the headers on
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
2003 Mach 1
i always pulled mine from the top (with bbk Longtubes still on the motor).. Take out the elec fans, and undo the steering linkage. You should be able to get that 3rd bolt on the starter from the front of the car.. Its annoying but is one of those slow turners haha..
Make sure you have a high enough ceiling because your Cherry picker is gonna need to extend , but just work it out and up, with the occasional push and pry. But ive done 4 motors from the top, 3 with bbk longtubes on it . Its easier if the trans if disconnected but since you say you have BBK longtubes , i take it , the trans is still on the car . Some may say pull the K , but for me ive always gone out the top and narrowed it down to start to finish in a couple hours .. keep at it
2003 Mach 1 - Oxford white - 5spd - IUP - Bolt ons ..
1998 Mustang Cobra
Everything is disconnected (including the tranny) except for the starter and the headers.. Say i hook the cherry picker up, and the drop the k member, and put a jack under the front of the tranny. would that work?
Also, i have not gotten there yet, but from experience where is the best place to hook the cherry picker up @?
2003 Mach 1
I've yet to drop a k-member on a car but I'd imagine that would work..
And get yourself a good chain and bolt one end to the back of your driverside head and the other side to where one of your idler pullies goes on the passenger side
Threads Similar to: Need Help on Pulling my DOCH
| Pulling The Engine | JStang14 | 99-04 | 5 | April 10th, 2008 10:25 PM |
| Pulling a Mach 1 4v | likopiko | 99-04 | 2 | March 30th, 2008 02:10 AM |
| Pulling the trigger | mustang fanatic | 2005 - 2010 | 11 | March 19th, 2008 08:14 PM |
| pulling heads,..need help | Hunt_chevs | 5.0 Mustangs | 8 | March 11th, 2008 02:20 PM |
| pulling | egghead | 96-98 | 1 | February 23rd, 2008 01:51 PM |
