exhaust rattle....
Old July 28th, 2010, 08:12 PM   #1
rst1523's Avatar
2003 Mach 1
rst1523 is on a distinguished road
exhaust rattle....
i have a magnaflow catted x-pipe and i think the heat shields for the cats are the prob. When the car has been run for a bit(45 min), i get a rattle around 2k rpm, i know it's the exhaust i'm just wondering if anyone else is having this same prob. and if so, what did you do to fix it? i thinking about cutting the heat shields off,but just want to check first. I know all of my posts have been problems but i swear i this is not my first mach. I bought it used and am now dealing with the last owners sh!t.
Old July 28th, 2010, 10:47 PM   #2
WabashaCobra99's Avatar
1999 Mustang Cobra
WabashaCobra99 is just really niceWabashaCobra99 is just really niceWabashaCobra99 is just really niceWabashaCobra99 is just really niceWabashaCobra99 is just really nice
I'm running Magnaflow cat-less X pipe and cat back and I'm getting rattle too. When I look under the car I can see that one of the cat back pipes is lightly rubbing the gas tank cover. I've adjusted as much as I can, but it still hits when I hit hard bumps. I'm probably going to cut a 1/4 to 1/2 inch off that pipe to put and end to it.
Check the gas tank cover, it's plastic (on my car anyway) so you will easily see any melting or abrasion.
http://dakotaboy88.smugmug.com/Art/Random-Stuff/i-xSjRPJj/0/O/MM-sig-temp.jpg
MM Cobra Club Member #97
MM's Resident Toy Maker
Minnesota!
Old July 28th, 2010, 11:00 PM   #3
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
Ryan Paymaster will become famous soon enough
Send a message via ICQ to Ryan Paymaster Send a message via AIM to Ryan Paymaster Send a message via MSN to Ryan Paymaster Send a message via Yahoo to Ryan Paymaster
The guy who owned my Cobra before me put on a SpinTech exhaust setup and it always banged around underneath. Did a terrible job putting it up himself and a lot of crap was installed improperly.
So yeah, I rattled too. Mine hit the control arm pretty good to give you an idea.
Slowly but surely creeping into the 12's on a stock N/A block...
Old July 28th, 2010, 11:03 PM   #4
1999 Mustang Cobra
Hit the control arm? What in the heck was that guy drinking to pull that one off...
Edit: I'm not familiar with 96 Cobras so maybe it's not that much of a stretch to hit a control arm.
Minnesota!
Old July 28th, 2010, 11:06 PM   #5
04MachOne's Avatar
2004 Mach 1
04MachOne is on a distinguished road
When I got mine, the guy before me had some flowmasters welded in and they did a shitty job and one of the hangers from the stock exhaust that was left under there was laying against the muffler, so at around 2300 rpms it rattled.
Old July 29th, 2010, 08:04 AM   #6
rst1523's Avatar
2003 Mach 1
it doesn't do it all the time, just i guess when the cats are heated pretty good. but i will check to see i'm have an issue like you. I too have welded in flowmasters
Old July 29th, 2010, 10:57 AM   #7
1996 Ford SVT Cobra
13.36@102
I wish I had a photo of it. The exhaust wraps up around the axle and when it came back down it was so misaligned that it was rubbing against the stock lower control arm. It actually put about a 1/4 indent into the control arm from where it was hitting.
This also goes to show how weak the stock control arms are as well, eh? Some metal exhaust beating on the side of it wore it down.
Old July 30th, 2010, 11:02 PM   #8
96MysticCobra is on a distinguished road
my exhaust rattles too. but the guy before me put in bbk pipes, cat-less x-pipe and flowmaster 40s. the x pipe wasnt bent enough and the mufflers rattle against the drive shaft at when my rpms lower. i just need to get the pipes bent a bit so i can fit them where they are supposed to be and can hook on to the hanger things.
Old July 31st, 2010, 09:50 AM   #9
04MachOne's Avatar
2004 Mach 1
Well sometimes if I drove it a certain way I could get it to not do it. Like if I went really slow past those certain RPMs it wouldn't do it, but I guess if yours won't do it at all until the cars been on for a while it does have something to do with them heating up. Good luck finding it.
Old July 31st, 2010, 05:44 PM   #10
rst1523's Avatar
2003 Mach 1
im pretty positive it's the heat shields on the cat resinating at 2k. I'm afraid to cut them off cause of the extra heat that will present cause of not having them. I'm going to hit them with a hammer and see if that will change anything. Just an idea, pretty sure it's not going to work
Threads Similar to: exhaust rattle....
Exhaust rattle or heat shield rattle 3.8mustang98 General Tech 0 July 22nd, 2010 04:09 PM
Exhaust Rattle? mineralmustang05 2005 - 2010 16 October 1st, 2008 08:28 PM
Exhaust Rattle killermach1 2005 - 2010 1 July 28th, 2008 04:46 PM
Exhaust Rattle Need Help...... 88stangGT 99-04 1 July 15th, 2008 05:17 AM
exhaust rattle deedub97GT 96-98 6 May 5th, 2008 05:23 AM
