SuperChargers for Mach 1
Old August 14th, 2010, 05:10 PM   #1
Zackqb2's Avatar
04 Mach 1
Zackqb2 is on a distinguished road
Well I'm in the market for a supercharger I've been looking at the Vortech's and the ProChargers, i would love to put a kennebell on my car but I don't have that much money and I'm looking to keep my bottom end stock for now. What are some of the things that most of you guys are running. And what are some good Chargers out there.
Old August 14th, 2010, 05:21 PM   #2
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Procharger P1sc kits used go for about 3k or under. some with and some without fuel systems. You can make 450rwhp really easy. Self contained and awesome customer service!
Old August 14th, 2010, 06:29 PM   #3
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
+1 a lot of Mach 1 owners use Prochargers.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old August 17th, 2010, 12:53 AM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
+2 for procharger. just keep it in a safe boost range the high compression will bite you if you don't
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old August 17th, 2010, 12:23 PM   #5
2003 Mach 1
12.87@ 109
2003MACHWON is on a distinguished road
everytime i have the money to put a P1sc kit on theyre going to like 5000 with everything, were are you guys seeing the 3000. If i can get one for like 3500 it will be mine
Old August 17th, 2010, 01:03 PM   #6
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Used
Old August 17th, 2010, 02:00 PM   #7
TRMach1's Avatar
2003 Mustang Mach 1
TRMach1 is on a distinguished road
For that same 3k, you could do a complete Eaton swap. Then, if you decide to build the bottom end at some point in the future, the sky's the limit with the big Kenne Bell's and Whipple's! Or you could look around for a used KB 2.1 kit that someone is trying to sell to finance a larger blower.
2003 Torch Red Ford Mustang Mach 1 5-speed
657 RWHP 635 RWTQ
My Mods
My Car
MODS: Yeah, it's got mods.
August 2012 AmericanMuscle.Com Calendar Centerfold!
Old August 18th, 2010, 01:24 PM   #8
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Originally Posted by TRMach1 View Post
the sky's the limit with the big F1A Procharger
Fixed
Old August 21st, 2010, 03:18 PM   #9
2003 Mach 1
12.87@ 109
How does the KB fit on the mach 1 i will have to take out the shaker wont I?
Old August 21st, 2010, 03:36 PM   #10
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
Some guys have used the shaker and the kb, but they're expensive. He'll I'll sell you my procharger for $3000.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old August 21st, 2010, 04:46 PM   #11
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
The bracket will need to be fabbed most likely and it most likely won't be functional. But you can still sit it on top of the blower for the looks.
Old August 21st, 2010, 05:57 PM   #12
04Machsy's Avatar
2004 Mustang Mach1
04Machsy will become famous soon enough
it just turns into an engine bay cooler
Old August 23rd, 2010, 10:17 AM   #13
TRMach1's Avatar
2003 Mustang Mach 1
First, Kenne Bell supplies the necessary brackets to mount the shaker to the KB 2.1 Mach 1 kit. Second, the shaker gets blocked off with an included plate, to eliminate water and bugs from entering the scoop and getting all over the blower and engine! Obviously, the scoop becomes non-functional, but be realistic, ain't no way the shaker is going to supply enough air to run a twin screw blower!!
657 RWHP 635 RWTQ
My Mods
My Car
Old August 24th, 2010, 05:08 PM   #14
2003 Mach 1
12.87@ 109
ohh ok that makes sense i guess, what the best way to buy a KB and prices
Old August 25th, 2010, 04:14 AM   #15
blown03mach1 is on a distinguished road
I have been running a P1 pusing just shy of 10#'s for 5 years and nearly 30K miles on my stock bottom. Another votre for the centi. I cannot prove it, but I would think the centi is easier on the stock bottom than the posi units as they buld boost much more rapidly and at a lower rpm than the centi. Again I cannot prove it, but it seems 8#'s all at once has got to put more strain on the stock bottom then say the centi which build boost proportionaly with rpm.
Old August 25th, 2010, 09:56 AM   #16
TRMach1's Avatar
2003 Mustang Mach 1
I've heard that trying to deal with them as a customer, and end user, can be a stressful experience. I think the best way to deal with Kenne Bell is through a shop, preferably one that has done KB installations, and has some kind of relationship with them, I know that's the way I've been working with them.
While that's a solid sounding theory, I don't think it'll pass the smell test. If your theory was correct, then there would be many more stock bottom end motors dieing from nitrous use. Nothing comes on harder than a 125shot of nitrous, which about equals the same cylinder pressures as running 8-10psi of turbo/supercharger boost. I ran a 100-125 shot on a stock block Mach 1 engine for almost 5 years and never had an ounce of trouble from it.
A properly tuned, low boost, PD supercharger should not be any harder on a motor than a centrifigal blower, or a turbo.
657 RWHP 635 RWTQ
My Mods
My Car
Old August 25th, 2010, 10:00 AM   #17
Baddbullitt's Avatar
2001 Bullitt
Baddbullitt is on a distinguished road
I'de save the extra cash and get a KB.. They are awesome.. I didn't regret mine.. Prochargers are awesome too, but nothing beats the constant torque and the sound of a KB!!! Good luck in which ever you get.. Can't wait to see some pics!!!
Bullitt Crew #16
MM + Cleavage Club #16
http://www.youtube.com/watch?v=NviuotZgIgg
Originally Posted by philly78 View Post
^^ is my Bestest MM buddy!!
Old August 25th, 2010, 10:10 AM   #18
I agree 100% about the juice and that has always had me shaking my head in disbelief that these stock bottoms are taking that stupid amount of tq that is made off of the juice.
I think the reason that people are blowing up the centi's is because 1. they either have a bad tune, 2. they drive thier stock bottom car like it is forged and beat the snot out of it, or 3. we centi owners need rpms to build boost and I would guess we spin the motors higher than the pd guys. Again, I am no expert, just looking at it from the outside. I trust those with the experience.
Old August 25th, 2010, 12:47 PM   #19
Jobra's Avatar
2004 Cobra
7.4@97 Eaton
Jobra has a spectacular aura aboutJobra has a spectacular aura about
My vote is with any type of positive displacement blower. Although Eaton swaps are cheap and make plenty of power, your better off saving for a real quality kit like the one KB offers.
NEW NUMBERS: 609/543
Old August 25th, 2010, 10:54 PM   #20
Zackqb2's Avatar
04 Mach 1
Thanks for all the info guys
Threads Similar to: SuperChargers for Mach 1
5.4l superchargers Exodus 99-04 20 April 6th, 2009 01:03 AM
Superchargers? 1997Stang 96-98 13 January 10th, 2008 03:05 PM
Superchargers? supercharged421 V6 Mustangs 15 November 25th, 2007 06:46 PM
Superchargers supercharged421 General Tech 10 November 23rd, 2007 09:28 PM
