1997 Mustang Cobra
rear-end ratio... steeper than i thought
Bought this car sight unseen. been really happy with it. I knew going into it that the previous owner was clueless about the diff. ratio. I just kind of gambled on that point. took it out on the highway for the first time today... I was amazed... 3000rpm at 60mph in 5th gear. What are these gears, 3.56? Higher? I might switch these out. a little steep for me.
What gears do you think i have?
"The greatest trick the devil ever pulled was convincing the world he didn't exist" |
04 Cobra
this website will answer most of your questions PaladinMicro
#3 | |
MM's Orangest
2004 Mach 1 Mustang
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
1997 Mustang Cobra
wow. what a helpful site. Thanks.
So I plugged in the rear tire specs (285/35/17), entered the 5 speed transmission I have, and played with the rear gear ratios until i replicated the speeds I was traveling at in the respective gears (1-5) All that to say, It seemed steep while driving 60 at 3000rpm... turns out i was right, the table has me at a 5.71 ratio. scary. anyone in the market for 5.71 gears?
1997 Mustang Cobra
Yep. The calculation is correct. I checked a second calculator and searched Summit's catalog. Turns out 5.71 gears are not too uncommon. What a mess. I'm switching them as soon as I have the chance.
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
dude what do you top out at thats crazy, the car probably reaches redline in 5th the very second after it finishes the 1/4 mile lol
2004 Bolt on & Cammed 3.9L V6 |
2005 Torrid Red GTO m6
Thats probably all it was even meant for.
i mean damn. Is first gear even usable? question though. Has your speed been calibrated with a speed cal or a different gear? Because if not chances are your only doing around 50 or so 3000 rpm's sound alot like 4.10's or 4.30's my gt would hit about that doing around 55 with the speed corrected.
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. Last edited by Hourofpain; August 18th, 2010 at 06:02 AM. |
1996 Cobra
Not fast enough.
5.71? Damn! Great if you got some gumballs and power behind um'...And you better bang them gears! Haha.
Mods: Full 01 Cobra drivetrain (Teksid block ) T56, 3.73s, Pro 5.0, Aluminum driveshaft, JLT CAI, BBK O/R X, SLP LM1s, Full welded in sub frame connectors
Assistant to the Manager
Id be happy to pace ya and check your speed for you man.
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
571's are for 1/8 miles lol too steep for the 1/4
GPS ftw
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
2003 Mach 1
damn...i just put 4.10's in mine and i spin 3k at 50 in 4th on stock tires. Your top end must suck, 120's-130's?
Priest of the Car Gods
How do 5.71s even fit? I thought the steepest gears that worked in a stock housing were 4.56s, maybe 4.88s.
Have you checked your speedo against anything?
1997 Mustang Cobra
All good points. You may be right. At least I hope you're right. The speedo may not be corrected... however, the speed limit was 60 in the area I was driving in and it's a pretty big speed-trap spot. I was just going with flow of traffic.
It is interesting, though... When the calculator told me 5.71 gears, I had never heard of that ratio before. I thought a mistake had been made until I searched 8.8 rear gears at summit.com and found them sitting right there at the end of the list... "5.71". Regardless, I was revving way to high at whatever highway speed I was traveling.
1997 Mustang Cobra
... and yes, you quickly blow through whatever impressive power band the boosted 4.6 has to offer.
I like the feeling of the gradual boost increase of a centrifugal supercharged/shallow geared car anyway... something that won't break the tires loose so easily.
have a buddy lend you the gps and check your speeds. most accurate way
MM's Orangest
2004 Mach 1 Mustang
If the speedo isn't corrected your car has fewer miles on it than you think.
^issue i had with the gt.
Rather frustrating
OP, did you ever verify the speedometer accuracy--just curious?
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
1991 mustang 5.0
you could just jack the ass of your car up and spin one wheel one revolution and count how many times the driveshaft turns. That will tell you what gears you have more accurately than some online calculator.
Threads Similar to: rear-end ratio... steeper than i thought
| Rear gear ratio | AdaBoNGT | 96-98 | 2 | May 18th, 2010 01:39 PM |
| what rear end ratio? | seanpat2006 | Classic Mustangs | 2 | October 15th, 2009 10:59 AM |
| Rear end ratio for Supercharged cars | discogodfather | 99-04 | 6 | September 25th, 2009 11:38 AM |
| Stock rear gear ratio? | Ntv69 | 5.0 Mustangs | 5 | November 16th, 2008 09:14 PM |
| rear end gear ratio | G.T. Rags | 96-98 | 37 | April 24th, 2007 12:31 AM |
