1998 Mustang Cobra
MMR Shortblock
Has anyone purchased an in stalled an MMR shortblock for a 96-98 cobra.
The block the use is from an 03-04 cobra and is cast iron. Pros? Cons? NEED HELP QUICKLY Here are the specs: MMR 4.6 Street Mod 600 (up to 600 RWHP) 2V, 3V or 4V The perfect replacement for your forced induction or NOS GT *Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed *New Ford Racing Cast Iron Crankshaft rated up to 600HP (8 bolt or 6 bolt) *New 4340 5.933 MMR (Modular Mustang Racing) I-beam Rods, these rods are shotpeened, magnafluxed and weight matched w/ ARP Hardware *New Forged Manley lightweight pistons *Speed Pro file fit rings (precision file fit to your application, nitrous, blower, turbo or N/A) * Tri-metal Rod and Main bearings *Complete Pro Assembly and Balancing for the smoothest, highest revving shortblock available, Pre-Lubricated with Royal Purple Assembly Lube and spin tested. Lastly 3 technicians sign off on your new engine prior to packaging and crating. $2500
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner |
MM's Orangest
2004 Mach 1 Mustang
The only con will be that it's iron and your previous block was aluminum. The pros are it can handle a bunch of power. Your heads and intake will bolt right up to this.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
MM's Orangest
2004 Mach 1 Mustang
It was a special edition Mustang GT that was built for use with nitrous oxide just like some of the Saleen Focuses.
2003 gt
5.4 32v on the way
you would be better off using your block and buying a rotating assembly from them.
1998 Mustang Cobra
Well, that was my plan, until i got inside the engine.
I spun two main bearings and burned the crank pretty bad. I'm not sure if my block is reuseable with out having it line bored. Buying the short block isnt a huge price difference than piecing it together, plus i could probably sell my forged rods. Will my computer harness hook right up to this?
MM's Orangest
2004 Mach 1 Mustang
It's a direct swap. Slap your heads, intake, wiring, ect ect onto the block MMR sends you.
1998 Mustang Cobra
Would i need to get the car retuned?
MM's Orangest
2004 Mach 1 Mustang
If you keep the compression ratio the same on your pistons as your old block no tune would be necessary. The only difference, like I said before, is just the increased weight from the iron block and the stronger components in the motor.
The only reason you would need a retune is if you change your compression ratio. If you don't change the piston compression, put the heads on, intake, wiring, all the old stuff. Pretend it was your old motor. Everything will be fine.
Threads Similar to: MMR Shortblock
| MMR | ia07gt | 2005 - 2010 | 47 | January 2nd, 2010 05:36 PM |
| just bought an mmr 900 shortblock! | B0B | 99-04 | 14 | June 2nd, 2009 08:15 AM |
| mmr 900 shortblock+nitrous=??? | Boostang | 99-04 | 8 | May 19th, 2009 08:00 PM |
| mmr 5.4 950 shortblock....??? | 94pacecarSVT | 99-04 | 8 | September 7th, 2008 09:44 PM |
| MMR? | mystang0673 | 99-04 | 20 | February 11th, 2008 04:10 AM |
