1998 Mustang Cobra
What Clutch to buy
Doing a rebuild, and noticed the Center Force Clutch was pretty burned. Figured i should replace while the motor is out. I have a Tri-Ax shift kit.
Any suggestions??
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner |
11 Mustang GT
Track times coming soon.
How much power are you making?
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune. |
Noob Slayer
13.82 @ 101.09
spec 3+
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
1998 Mustang Cobra
currently right about 400RWHP, but if i crank the boost another 4-5lbs my HP will obviously increase.
11 Mustang GT
You have to have an idea of how kuch power you will be making to get the correct clutch combo. Call promotion powertrain and they will ask you how much your car weights and how much power is making and they will tell you what is the best clutch setup for you.
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
this will be my next clutch. i currently have a spec stage 2 and i love it. it grabs harder than stock but is still something that is very streetable. clutch pedal effort isnt terrible either.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
1998 Mustang Cobra
ok..Ill give them a call. I will have to figure out my weight first. I am going to an MMR short block, which is cast iron compared to my stock aluminum one, plus i have several mods.
11 Mustang GT
Weight dosnt need to be spot on. Just an estimate will do. Same thing with power.
1998 Mustang Cobra
Manolith- In your Mods i see you have an aftermarket fly wheel. Do you recommend i replace mine or just have it resurfaced? What are the pros and cons?
11 Mustang GT
well i dont know about resufacing because there are alot of places that will do a half ass job.. if you know a place that can really do it right and balance the flywheel then you can stay with yours. sometimes they cant be resurfaced tho. but whatever you do make sure that you get either a new flywheel or resuface yours before you install a new clutch. Im using an aluminum flywheel. if you have the money i say replace it.. make sure that you buy new bolts for the flywheel and presure plate. they are cheap at lethalperformance.com .
#11 | |
Noob Slayer
13.82 @ 101.09
the + makes the stage 3 so much better in a street app. dont they make a 2+ also?
2005 Torrid Red GTO m6
Dont get a king cobra. I have it in the cobra and it sucks.
And im not sure to recommend the stage 3 I have a stage 3 in the gt and it makes city driving a bitch sometime. However its fucking fun and the clutch is comfortable and easy to drive. Get a stage 2 perhaps
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
specs break shafts...
[SIGPIC][/SIGPIC] [LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR] [COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR] [COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR] [COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT] |
2004 Cobra
7.4@97 Eaton
Got a RAM HD right now and putting down the numbers in my sig with 0 problems running hard at the track.
![]() NEW NUMBERS: 609/543 |
1998 Mustang Cobra
how is it for normal driving?
Spec = Breaking input/output shafts and chattering...
RAM HD = Smooth. 04 cobra clutch (might not be enough clutch) = BEST..
I.D.G.A.F.
Fuck all of those suggested! Get a Mcleod, they're the best for a reason...
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
Assistant to the Manager
I runa spec stage 3+.
But if you don't plan on going over 500 hp a stage 3 would be more than enough clutch.
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
2000 Ford Mustang GT
I second the McLeod clutch. Do it and call it a day. There is a reason they're so expensive.
#20 | |
my spec is almost silent....
Threads Similar to: What Clutch to buy
| Where to buy clutch cable and TOB | Nitmare67 | 99-04 | 4 | July 7th, 2010 10:05 PM |
| which clutch to buy?? | silverstang | 2005 - 2010 | 12 | September 20th, 2008 09:41 PM |
| Which Clutch sould I buy? | BrandonxSD | Classic Mustangs | 3 | June 7th, 2008 10:33 PM |
| Clutch time, what else to buy? | DanTheMan | 99-04 | 55 | May 16th, 2008 08:25 AM |
