Think You Know Your ABS? This One Has A Few Stumped
Old August 25th, 2010, 05:41 PM   #1
scount757 is on a distinguished road
I have a 99 Cobra and the abs light is on. All fuses and relay are how they ought be. The module we have no idea if it is good because we cannot get any power to it. Where in the system can it be losing power it the block is not getting it? The main harness under the battery has no corrosion to it whatsoever. I am at a loss as to what to check. No traction control as a result of it and that is no fun in the rain or a gravel road
Old August 26th, 2010, 04:16 AM   #2
86er's Avatar
have you tested for voltage at the module? Should be a green wire I believe coming out of the harness, if you have voltage there, obviously the module is then bad, if you dont have voltage, keep tracing back with that wire until you find where you have voltage. Could be a short, bad ground, chafed wire
Just a truck
Old August 26th, 2010, 12:43 PM   #3
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I was going to guess bad ground. My ABS light keeps kicking on every so often because of one.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old August 30th, 2010, 05:37 PM   #4
Look Ma! My First Post!
semperfi09 is on a distinguished road
i have a 04 mach 1 with the exact same issue i checked the darker green wire coming out of the harness it it has very little voltage but it was enough to make the test light illuminate does this mean the module is bad ?
Threads Similar to: Think You Know Your ABS? This One Has A Few Stumped
this one has me stumped. Need help ocsailor86 96-98 9 March 27th, 2010 01:24 PM
Abs vs non abs for rear end swap? bansheex 94-95 2 March 17th, 2009 08:09 AM
ABS and NON-ABS Axles... HELPSSS John's_stang 99-04 6 October 8th, 2008 12:43 AM
I got stumped Regency 2007 The Clubhouse 19 June 20th, 2008 01:45 PM
stumped... jessy_is_rad Classic Mustangs 19 April 30th, 2007 01:13 PM
