Should I Get A T56?
Old August 28th, 2010, 01:01 PM   #1
rst1523's Avatar
2003 Mach 1
rst1523 is on a distinguished road
Should I Get A T56?
ok so i just got a good deal on a used t56, but i'm not sure if i want to buy it cause the 3650 i have has better ratios in the gears and i feel that getting that in extra gear is not worth it. I have 4.10's in the rear and i'm afraid that changing the gear ratio in the trans will make these rear gears worthless. I don't know too much about trannys yet so any input would be awesome! Also if everything sounds good to me and i buy it what all do i need off the donor car to make this work? Thanks guys
Old August 28th, 2010, 01:06 PM   #2
manolith's Avatar
11 Mustang GT
Track times coming soon.
manolith will become famous soon enoughmanolith will become famous soon enough
t56 is great.. just get 4.30s or 4.56 gears. the only think i hate about the 3650 is really the stupid overdrive fifth gear. if it had a decent or useful 5th gear then i would say that is not worth to get a t56.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune.
Old August 28th, 2010, 01:18 PM   #3
rst1523's Avatar
2003 Mach 1
i just put in the 4.10's like 2 weeks ago. and spend like a grand on parts and install. I actually like the 0.620 ratio in the 3650 5th gear. the only reason i am thinking about it is cause of the deal i can get and the fact that my third gear slightly grinds sometimes
Old August 28th, 2010, 01:20 PM   #4
manolith's Avatar
11 Mustang GT
well you can have a built 3650 for about 1600 bucks if you like them so much.. ofcourse thats with a 26spline input shaft and upgraded syncos and beefed shift fork. they can handle over 700hp. i have one and i like it but i hate 5th gear. i actually hate it alot.
Old August 28th, 2010, 01:22 PM   #5
rst1523's Avatar
2003 Mach 1
is that roughly parts and labor?
Old August 28th, 2010, 01:28 PM   #6
manolith's Avatar
11 Mustang GT
well you have to pull your transmission and install the new one. they will ask you to turn yours in as a core and then you get the built one. i got mine from promotion powertrain. i paid a bit more for mine because i had a broken bellhousing and i also got a short shifter from them.. i paid 1990 bucks for everything but the transmission by itself is about 1600-1700 bucks. you will need a new clutch disk if you do go with the 26 spline input shaft which is a must.
Old September 11th, 2010, 05:09 PM   #7
rst1523's Avatar
2003 Mach 1
bump
Old September 12th, 2010, 12:59 AM   #8
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
well...the t-56 is just awesome, so i dont really see the problem here...besides for the fact that its not already in your car. if you decide to not use it let me know cuz i might be interested in it
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old September 12th, 2010, 01:45 AM   #9
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I just got a T56 put in my car. Today was the first day I drove it. First gear seems twice as long as the 3650. The nice thing is I'm not spinning leaving the line on street tires like I did with the M5, but I'm running a little more power than the average N/A Mach/Cobra so that's nice. And I already love the 5th gear in this thing. It's perfect in those 45-50 MPH zones.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old September 12th, 2010, 08:58 PM   #10
static74 is on a distinguished road
im planning on doing the t56 swap, seems straightforward. im tired of lockouts in my 3650
Old September 14th, 2010, 05:25 PM   #11
rst1523's Avatar
2003 Mach 1
thanks guys i'll keep that in mind. what all will i need besides the tranny?
Old September 15th, 2010, 02:25 AM   #12
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
I think you will need a different length driveshaft...?
I should know I have one lol but i didnt do the install
I have it with 4.10 gear and I like
the gears are really tall but close ratio. first will go to 50 lololol but going 35 im in 5th gear at around 1700rpms
anyways, it's recommended
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Threads Similar to: Should I Get A T56?
T56 on a 5.0 Moses Man 5.0 Mustangs 16 March 10th, 2009 11:17 PM
t56 adrenaline=lifeline 4V / SVT 5 September 27th, 2008 08:36 PM
T56 adrenaline=lifeline 99-04 4 September 25th, 2008 03:11 AM
t56 usmcsawgunner 5.0 Mustangs 3 May 28th, 2007 11:46 AM
